Need part number for Clevite 77 Main and Rod Bearings
Old Jan 22, 2013 | 03:26 AM
LT1UltraZ's Avatar
I cant seem to find a part number for these...
Clevite 77 Main and Rod Bearings...STD size for a 85 22RE
also need a recommendation on the best piston rings and the part number
thanks
Old Jan 22, 2013 | 08:15 PM
E-ROC's Avatar
thanks
clevite part #'s for 22re (found thru google).
main bearings= TW-463S
rod bearings= CB-1218P
Piston rings. NPR reference number is SWT-10103. And as far as I know piston rings have to be ordered after you determine the exact piston width. But dont quote me. Im not a pro.
Rod and main bearing set on e-bay= http://www.ebay.com/itm/Rod-Main-Bea...-/290420995620
Best I could find on google for you.
Old Jan 23, 2013 | 01:46 AM
LT1UltraZ's Avatar
thanks!
TW-463S is for thrust bearings though?
Old Jan 23, 2013 | 06:06 AM
MudHippy's Avatar
Took me less than 2 minutes to find the part numbers on MAHLEClevite.com.
CB-1218P is for standard size connecting rod bearings
MS-1590P is for standard size main bearings
TW-463S is for standard size thrust washers(bearings)
Old Jan 24, 2013 | 03:27 AM
LT1UltraZ's Avatar
Thanks Mudhippy
i got 1 more question for you if you dont mind, which rings would you recommend? pistons are stock, so is the block, it just going to be a quick hone with a drill bit as stock crosshatch is still on there.
I was planning on going with Total seal gapless but i would love to hear your opinion. I also noticed in one of your post you have said not to even bother checking the ring gap, i was hoping you could expend on that a little. Thanks!
Old Jan 24, 2013 | 05:33 AM
MudHippy's Avatar
NPR
Checking ring gap is just unnecessary in most cases(especially stock). If the bores/cylinders have been sized correctly, then the rings that are the corresponding size will already be correctly gapped(within factory specifications) right out of the box. This is because piston rings are manufactured under extremely tight tolerances to be exactly the size they're supposed to be. And because piston ring gap specs are fairly standardized in the industry(nearly the same for all makes).
Old Jan 24, 2013 | 04:55 PM
LT1UltraZ's Avatar
NPR
which bearings would you recommend?
ACL / KING/ Clevite 77 ?
Thanks
bigjstang
Jun 2, 2025 03:56 PM
msane99
Jul 11, 2015 08:08 PM
Gamble_STi
Jul 7, 2015 07:54 PM
cyclist231
Jul 7, 2015 12:56 PM
ptb12
Jul 5, 2015 01:49 PM
