3VZ-E Connecting Rod--Install Piston?
Old Jan 8, 2013 | 03:51 PM
cwgrizz's Avatar
First, I am new to this forum. Having not worked on many Toyota engines, I have a question. My son's 3.0L 3VZ-E had the common problem of a blown head gasket. As has been stated throughout the forum, pistons and cylinder walls were also damaged. New oversized pistons were installed on the connecting rods by a machine shop my son found (I am not sure about the quality of their work). So: This question is to determine if they installed the pistons on the connecting rods correctly. On the left bank, what direction does the connecting rod oil hole for spraying the cylinder walls go. Does it face the center of the engine or the outside? Do the rod markings determine the front of the piston rod? I have attached some pictures of the rod to help illustrate.
1. Rod marking
2. Rod side without marking
3. Oil hole for spraying Cylinder wall
Thanks
Attached Thumbnails 3VZ-E Connecting Rod--Install Piston?-rod-marking.jpg   3VZ-E Connecting Rod--Install Piston?-rod-no-marking.jpg   3VZ-E Connecting Rod--Install Piston?-rod-oil-hole.jpg
Old Jan 8, 2013 | 04:14 PM
MudHippy's Avatar
See page EG2-116 http://personal.utulsa.edu/~nathan-b...ne/69cylin.pdf
Connecting rod front (mold) mark:
A1, 136, 1B, 8A, C3 or etc.
I can see that they torched those rods to remove the pins. I'm no expert, but I woudn't have done that. Nor is it the factory recommended procedure for removing them.
Old Jan 8, 2013 | 04:48 PM
cwgrizz's Avatar
Thanks, Mudhippy,
That's what I was looking for. The Y5 is the marking and the pistons are pressed on with the proper alignment. As to torching the rods..................well can't comment on that. I'm just putting it together.
Old Jan 8, 2013 | 05:18 PM
MudHippy's Avatar
It may or may not be any cause for concern. All I know is they didn't come from the factory like that. And it seems a little unnecessary...especially having been done in a machine shop. Where one would assume the proper tools/equipment to do it without the application of intensely high heat, would be readily at hand. I can't help but call it just being plain lazy...cutting corners...and the like.
Old Jan 9, 2013 | 04:01 AM
Pat8942's Avatar
This might help with assembly, I see this was already posted, so disregard this post
File Type: pdf
some drunk guy
Aug 3, 2021 06:09 PM
Bourbonblues
Dec 15, 2017 05:43 PM
voiddweller
Sep 28, 2015 11:21 PM
JPV
Sep 28, 2015 03:15 PM
old87yota
Sep 9, 2015 12:39 PM
