Sponsored by: CARiD
Having a Brake Issue
Old Jan 3, 2013 | 03:40 PM
efi88's Avatar
Exclamation Having a Brake Issue
I have been googling all day long and haven't found anyone with a similar issue. This thing is leaking. Its on the rear passenger side of my truck tucked in above the leaf spring.
It causes the brakes to lose power after 10-15 seconds of use. Is it called a "load sensing proportioning valve?" What should I do? Bleed the brake lines and replace? I have worked on motorcycles before, so I am mildly mechanically inclined.
Attached Thumbnails Having a Brake Issue-iqiim.jpg   Having a Brake Issue-3ddhz.jpg
Old Jan 4, 2013 | 11:28 PM
wyoming9's Avatar
Red face
If it is leaking it needs to be replaced. I have never heard of being able to rebuild them.
If it is the valve itself and not one of the lines that cracked. as long as it leaks it is going to draw in air.
You have two choices replace it with a new factory one or put a manual valve on.
Lots of threads on doing that.
Old Jan 4, 2013 | 11:31 PM
DeathCougar's Avatar
Its called a Load Sensing Proportioning Valve, or LSPV
I believe its possible to get them new, though used may be a cheaper solution.
Old Jan 5, 2013 | 06:05 AM
efi88's Avatar
Thanks guys, I'll post pictures of my progress. I want to do all the work by myself, if I can.
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 9, 2015 05:58 AM
