95 won't fire up.
Fire needs 3 things: fuel (gas), source (spark) and air. You've already eliminated fuel and source as the problem so the only thing left is air. I don't see how an intake could get clogged without you knowing it, but your catalytic converter could very well be clogged (the engine can't inhale fresh air to fire again if it can't get rid of old exhaust fumes). You could also be having a problem with your AFM. If it's not plugged in or gone bad the computer won't let the engine run.
I don't think it would be a valve problem. Even if you had a stuck or burnt valve the engine would run like crap, but it would still run. Start by checking your AFM on the intake filter box. Make sure the meter itself is still within specs and check the wiring for any damage too. Make sure you're getting voltage to the meter. If that checks out good move to the catalytic converter and make sure it's not clogged.
I unplugged afm and won't start plug back in and still the same. Did dyno with jumper wire from te1 to e1 and it just flashes constantly. Timing I'm not sure it has spark but not like a lawn mower all fast, there's a space between sparks not far apart.
What's the history like? Have you done any repairs recently?
Did you go to start it and this just happened?,
or has the rig been acting funny lately?, ya know any symptoms that may have caused this.
I just recently bought it, with fuel tank off, cause they thought it was the fuel pump. I put tank back on and pump in and went to fire it up and nothing, it cranks, has fuel, has sparks at plugs when I take them out. Sprayed ether and still wont attempt to sputter or start. Only has 55,000 miles, everything looks clean don't look like much has been serviced.
You still need to check your afm with a meter and make sure thats not the problem. You said you unplugged it and it didn't run (which is what it will do anyway) but it didn't run when you plugged it back in. If it's bad the truck still won't run so you need to confirm if it's bad or good.
Make sure all your vacuum lines are connected and hooked up to the right spots.
Had 2 tiny lines not connected after I did my head gaskets and it wouldnt fire up or even begin to try to start. Connected them and it fired up right away.
I know the 22re and the 3vze are very picky about it, they both have a very strong vacuum.
I would think you could still check that.
Now I'm wondering about fuel pressure.
The AFM maybe faulty but its not relevent during the cranking, http://www.autoshop101.com/forms/h23.pdf page 6, spark is triggered directly by the cam sensor (NE). Meaning it should fire with starting fluid momentarily.
You could try dropping the muffler also, but I'd expect atleast a sputter from starting fluid.
If it won't run on ether... Its not getting enough spark, at the proper times. (Indicating bad plug wiring or other Timing issues) Embossed on the Distributor cap is a #1 make sure this goes to the front cylinder, clockwise the next one is #3, then #4 and finally #2.
How healthy was the spark, at the distributor side of the igniter/coil? It should jump atleast half an inch there, and a similar distance at the spark plug.
Check the spark gap in the distributor.
Throw a cheap set of plugs at it?
Did you change the fuel filter, or test the injectors and fuel pressure?
Pull the valve cover and make sure that everything that should be is moving?
And just for future reference.. When Looking at a vehicle with "fuel delivery problems" It's best to bring a can of starting fluid with you, if it doesn't sputter or run cut thier price in half atleast.
Search for "Factory Service Manual" aka. FSM It is you new verys best friend. Someone might even link to one before you get back out of bed, but it won't be me.
Here's the latest, drained gas tank and sprayed ether just for giggles in the intake, and it sputtered a little very little, but tried it again and nothing, added new fuel and still nothing, I have pressure in the tank when empty, but nothing with fuel, cause when I remove the gas cap there isn't that ppisssssst releasing pressure, but does empty. I don't really know how to check a lot of the above items.
