Full fuel glass.
No...
but, you definitely have a float problem. 3 things, either the float needle valve is stuck open, preventing the fuel to stop flowing, or the float itself has become saturated with fuel preventing buoyancy, or the float, which controls fuel level, is mis-adjusted.
yea i def am going to rip the carb open tomorrow and look. I found out i had a screw missing leading to an actuator pump of some sort on the passenger side of the carb right near the throttle cable, its on the same flywheel that the idle speed adjustment is on.
jerusry
Oct 19, 2015 05:28 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
