96 4runner 3.4 4wd front wheel bearing help
Old Nov 29, 2012 | 03:33 PM
unsuperman's Avatar
So i just got my 5speed, 3.4L, 96 4runner sr5 4wd. love the truck, but it needed a nail removed form the rear tire.
while i was at midus they said the drivers side front wheel bearing is junk and needs to be replaced. they want some 400$s to "repack" it, whatever the ˟˟˟˟ that means.
i see wheel bearings are 60-70$ online, but i also understand they are pressed in, which i can not do without a press, which i dont have, or have access too.
can i buy the front "hub" or whatever they call them on 4runners with the wheel bearing in it used anywhere? is there another answer here for less then 400?
how do i know if its really bad? they hiit the tire when it was mounted and lifted on a lift, and said "when i hit the tire you can tell its bad". im pretty automotively inclined, but i know zero about wheel bearings.
someone help me, also im in aurora colorado near the aurora mall if anyone local can help...
6th Gear
19
Dec 10, 2019 07:31 AM
Csefiroth0
Jun 30, 2015 02:19 PM
AustinTaco
Jun 21, 2015 09:54 AM
Gene
May 25, 2002 02:39 PM
