Sponsored by: CARiD
reverse lights out
Old Nov 11, 2012 | 04:20 PM
echols90's Avatar
reverse lights out
I have a 91 4 runner and i recently replaced the clutch ,and after I got done putting everything back in my reverse lights don't work I made sure everything is hooked up right. I also changed the fuse and bulbs does anyone have an idea of what it could be?
Old Nov 11, 2012 | 04:33 PM
dropzone's Avatar
Fossilized
I would recheck the connect at the backup light switch on the transmission
. When I did mine it looked fully seated but wasn't.
Old Nov 11, 2012 | 05:52 PM
echols90's Avatar
Yea I checked it multiple times and made sure it had good connection but its still not working for some reason, I was thinking of replacing the switch to see if thats it.
Old Nov 12, 2012 | 12:03 AM
wyoming9's Avatar
Red face
If you don`t have a multimeter now is the time to buy one!!
Simple to check the switch put the transmission in reverse see if you have continuity across the pins on the switch.
This is where having a meter with the audible continuity signal maker it nice
You can also check for voltage coming into the switch.
in the course of doing the clutch is it possible the plug could have got dirt in or the pins could have got bent??
AkitaDog
Sep 1, 2015 08:05 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
rchavis
Jul 27, 2015 07:41 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
