Can you use stock gauge cluster in 94 Toyota after doing Chevy 350 swap
I'm doing a Chevy sb swap in my 94 toyota. I want to be able to use my stock gauges so I'm wondering if anyone has done it and if so how.
Thanks!
Thanks!
First you need to buy a factory toyota electrical wiring diagram manual , I bought mine from ebay for about $40.00. Under passenger right foot kick pannel is where your toyota Engine harness plugs into the body harness. Cut your toyota engine harness about 4 inches after the plug. Then use the manual to find which wires to wire in engine sensors. On my swap for the oil pressure i added a " tee " and screwed in a toyota sensor and ran a wire to body plug. I drilled and tap to put in toyota temp sensor and ran wire. Same for tach. All my gauges work like stock. Toyota manual is not very easy to read . When your ready to do it let me know i will help ya. Have fun
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
