Starting issue
Old Oct 21, 2012 | 07:10 PM
txyodaguy's Avatar
Starting issue
I have a 1985 4x4 Toyota p/u with a 5 speed 22r with a webber carb. i just put in the new 22r and new battery and new starter. Problem is i try to turn the motor over and it sounds like the starter is not getting the power it should to turn the motor over fast enough. a very slow slow crank. not near enough to start the motor. anyone have any ideas as to what it could be?
Old Oct 31, 2012 | 09:20 PM
ebence's Avatar
Check your ground cables. I would start with the main from your battery to the chassis. Clean up the contact or replace and see what happens. I had the same issue and that did the trick.
Old Nov 1, 2012 | 06:34 AM
txyodaguy's Avatar
Figured it out..... The ground cable from sylonoid to block was mounted to the motor mount bolts. Kinda hard to pass electricity through rubber... : /
Got it started and beautifully timed. Runs like a champ! Time to get a snorkal kit for the carb and hit some trails.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Avenged
Jul 9, 2015 07:55 AM
