86 4runner tailgate trim removal
the license plate lights and window switch on the rear trip piece dont work and I wanted to figure out how to get the trim off so I can look at it. I honestly have no idea
You'll have to take off the carpet and the inspection plate on the inside of the tailgate. There are 2 tabs on the inside of the tailgate that hold that trim piece on, you may or may not need to remove the glass as well, you might be able to just drop the tailgate and extend the glass so you can access the tabs.
Here's what the backside of the TOYOTA panel looks like:
One screw on each side and a press in stud in the middle:
http://www.flickr.com/photos/72188695@N05/8098822335/
Close up on the stud:
http://www.flickr.com/photos/72188695@N05/8098822469/
Close up on the one of the screws:
http://www.flickr.com/photos/72188695@N05/8098832028/
I always have the window in the closed position and have the tail gate open.Remember closed is up and open is down.
I just close the window enough to get at the nuts and disconnect the switch.
simple to unplug the motor and operate the motor in the direction you want. With the tailgate down although Toyota calls it the rear hatch.
I have found the license plate lights here in the salt belt just rust away.
For what it is worth the license plate lights the blubs are changed from the outside if you look up from the bottom
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
FS[NorAtl]: 1989 pickup beds and leer cap Rhode island
mickyd9990
Jul 6, 2015 09:01 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
