Clutch line bracket location, 22re
This for a 22re, 94 pickup. I'm getting the new motor all hooked up and I can't remember how the bracket for the hard line that screws into the slave is supposed to mount. Failed to take a picture of it. I also don't have a bag with a bolt for the bracket, so it must either be held with one of the bellhousing bolts or maybe the lower starter bolt? If anyone has a pic or wouldn't mind taking one, I would appreciate it a lot. Been cruising through pics on google and can't find one
Where does it look like it would go??
i mean as long as it works
i don`t have any that year .
But the eighties ones mount on the frame with a clip like a brake line.
then the rubber line goes to the steel line near the firewall. and a steel line goes to the slave cylinder
Hmm the bellhousing bolt right under the starter is too big to go through the bracket. And when you mount up the slave it really seems to go through the bottom starter bolt. I just can't seem to get it
Or there. I actually didn't secure it when I reassembled my motor because I was having starter issues and it worked out better getting pushed to the side.
I can see how it would go through the lower starter bolt. When I was trying to reinstall my starter I kept blindly hitting the bellhousing hole. They are right on top of each other.
Sep 4, 2015 09:27 AM
