86 Truck, shifters stuck in 1st and 4 low??
Truck needs a clutch kit.I'm stuck in 1st gear and 4 low by my house,hubs free.How can I get it into neutral to move the other stick out of 4 low?I do have a clutch cancel button if that helps.I'm ignorant on everything.A fellow is supposed to work on the clutch replacement this week ,but that's a half a mile away solutions,suggestions?....thanks.
i have had to put pressure one the 4wd lever when it was in 4 low hubs locked and give it a little gas, let off and pull it out of 4 low on decell.
once it was out of low range it shifted fine.
its like it binds up, so you should shift out of low range while you are moving.
voiddweller
19
May 2, 2016 09:10 PM
saphirekosmos
Jun 22, 2015 10:26 AM
Mr.Black
Jun 21, 2015 10:17 AM
