General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Low Oil Press. Switch
Old Sep 12, 2012 | 02:50 PM
robark's Avatar
I'm thinking about installing a low oil pressure switch in a 1987 Toyota pickup. What wire would you recommend I splice into to shut the engine down when low oil pressure is sensed. My grandson doesn't seem to get the message about keeping check on the oil in the engine.
thanks
Old Sep 13, 2012 | 07:26 AM
MudHippy's Avatar
Well, there's quite a few different ways it could be done. But after some fairly long deliberation, I've decided which way I would do it. I would put such a switch between the EFI main relay and ground. One of the 4 terminals/pins on the EFI main relay connects to ground(body/engine). That's the circuit I would use. Don't ask me why...
Anyhow, whichever way, you want to cut power to the +B and +B1 terminals/pins on the ECU, or power from E1 to ground(engine/body). That will kill the engine.
See this page from the FSM showing the ECU power supply circuits.
http://personal.utulsa.edu/~nathan-b...37efimainr.pdf
jbv808
Aug 6, 2021 04:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Gamble_STi
Jul 7, 2015 07:54 PM
