Gas mileage slowly decreasing, slight hesitation constant
Hello all,
I am trying to think outside the box on how to fix this 3.4 Here is my original post from a good few years ago.
The symptoms:
3.4L currently has 140XXX miles and runs decently. It hesitates occasionally at start-up but seems to idle well and I can't really detect a miss on any of the cylinders. I do not have any CEL codes nor have I in quite some time. I do have Airbag, VSC, TRAC lights and no horn due to a clock spring I believe. I am currently averaging less than 200Miles to the tank. That is with 305/75's so probably a little over 200 with stock speedometer gear but not much. If I really run the tank down low I can get 220 miles out of a completely empty tank. I have been running the 305's for the last 6-7 years and the mileage has been slowly decreasing so I do not believe the tires effect to mileage is a factor. My driving style has not changed much if at all and I am driving mixed mileage of street and highway. When I drive long distance I can get up to about 250-270 to the tank on flat ground on a good day with a tail wind.
What I have done
-I have also always kept the tires maxed recommended PSI
-I rotate and balance the tires with every oil change every 3000 miles.
-I also get the alignment done at least yearly.
-I am running full synthetic oil and run injector cleaner every 4-8 tanks (depending how often I remember).
-I replaced Air filter, plugs and wires and PCV a few months ago with no resolve
-I can't find a single vacuum leak anywhere on the motor.
In 2007 I replaced Air fuel sensor and O2 sensor.
In late 2009 at around 100XXX miles I replaced the timing belt and water pump, fuel filter, Air fuel sensor and O2 sensor (Actually bought Bosche in 2007 then went back and re-bought Denso after counsel in my previous thread). I also cleaned the MAF sensor and throttle body.
In 2011 I replaced the entire charging system with a Delco HO alternator, Optima Yellowtop Battery and new 4GA grounds and power wires.
The evap, vacuum, fuel and exhaust systems are all bone stock.
My questions
I am curious if other things could cause Airbag, VSC, TRAC dash lights to go off that might have an effect on fuel consumption? Closed loop?
Anyone ever heard of MotorVac? Here is a link to a thread talking how well it works.
Other things I should be looking into? Coolant Temperature Sensor, IAC, Throttle Position Sensor, Catalytic converter, fuel pump or even injectors?
I am really at a boiling point and about to sell the toy out of frustration. I get better mileage in my CJ-7 on 35s with a 4.2L tractor motor than I get in my DD 4runner.
Any input is appreciated.
-Me-
The symptoms:
What I have done
My questions
-Me-
What brand/type of spark plugs did you install? Any discolored fluids, trans, coolant, motor? Are the brakes releasing, possible drag on axles. Feel for excessive heat after driving. The odd startup would point me to the incorrect spark plug, first of all. possible clogged Cat. does it have good pulling power? You said it had no codes, right? Possibly a sensor. Or maybe a leaking fuel injector. Floods the cylinder after shutdown and cant fire up correctly. Could also explain the poor MPG.
http://www.toyota-4runner.org/proble...ghts-only.html
http://www.toyotanation.com/forum/74...ine-light.html
Heres a few threads that may get you in the right direction.
Hesitates when you first start it and hit the gas but then fine the rest of the drive or...?
You cleaned the MAF in '09 and not since? How's that look?
If you were to come up with a list of affordable parts that are cheaper/easier to replace than troubleshoot for this problem...Ideas?
The last couple of years I've been living in Boston and haven't hardly driven it so I didn't even try to fix the problem with mileage. I've been driving and working on my other rig a lot so as long as the runner started and got my wife to and from work a few miles from my house, I didn't care if she had to mash a little harder on the petal or pay a little more in gas. Lately she has been complaining about the mileage...
I guess what I am saying is that no matter what stage of tune up the truck is in, since 2009 the truck has been getting bad mileage so that leads me to believe that it is something I haven't touched that is going bad or faulting. For reference after I bought it in 2006 and put the lift and tires I would regularily get over 300 miles per tank and close to 350 per tank on the highway.
-Me-
I was thinking more your hesitation and it's one of those maintenance things that costs only a little time and some cleaner if the wire's dirty.
I'm interested in seeing if you find the culprit to your mileage loss, many of us are in your boat though in my case a lift, bigger heavier wider tires, a roof basket and lights and extra weight in mods are likely a large piece of it. I use fueleconomy.gov to keep track of mine so issues are easier to spot.
Do you have any white smoke on startup from the exhaust. I remember reading about an early head gasket issue where the truck was rough until it blew out the coolant. Could also explain poor mpg. I'm probably wrong but something to keep in mind.
If you wanted to do a quick check, pull each plug and look into the cylinder. If it looks super clean, that would be the tell. It cleans out the carbon so it would usually clean inside.
Tacoma1313
Aug 17, 2015 05:44 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
anniesball
Jul 30, 2015 12:14 PM
2009, 220, decrease, decreasing, empty, full, gas, hesitation, highlander, idle, loss, mileage, miles, mpg, mustang
