60 degree vent temp on 2003 tacoma
30 degrees below ambient temperature is USUALLY the best performance threshold i ever see and i work at a dealership on low mileage cars. if you're getting 60 on a 95 degree day that's pretty good in my book
in a GOOD working system, vent temp should be 38 to 44 degrees. it sounds like your low on refrigerent, but Lycanistic is right, humidity will affect perfomance, more humidity, means more ice build up on the evaporator. also take into account why you might be low. you might have a small leak, or moisture contamination, or it might be overcharged. if you really want it to work good, take it to a shop so they can pressure test it, and vacuum test it. and go from there.
the1998sr5
15
Jul 14, 2020 08:35 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
dropzone
Aug 11, 2015 05:16 PM
TJWilly
Jul 31, 2015 02:05 PM
Poncho0206
Jul 10, 2015 06:21 PM
