Sponsored by: CARiD
Oil overfill from jiffy lube!! Help and advice
Old May 24, 2012 | 03:43 PM
MaxwellE54's Avatar
Cool Oil overfill from jiffy lube!! Help and advice
Alright guys im a little stressed to say the least. I got an oil change from lame jiffy lube and I checked my oil and its about half an inch passed full. Maybe a couple mms more. Right before that next line with the set of numbers after it. Im assuming its about a quart to quart and a half over. What's your input? Fine? Or drain? If so what's the easiest way, just got my runner. Its a 91 3.0 auto 4x4.
Old May 24, 2012 | 04:03 PM
Inferno451's Avatar
Your engine doesn't care. I always overfill mine since it burns a little. You can drain some out if it makes you feel better.
Old May 24, 2012 | 04:07 PM
Teuf's Avatar
Crack the drain plug and NEVER go to Jiffy Lube. DIY.
Old May 24, 2012 | 04:20 PM
StewsRunner's Avatar
x2 ^^^ on doing it yourself. . .
Old May 24, 2012 | 04:30 PM
aa1911's Avatar
DIY would be my first choice also (x3 i guess) but if they overfilled you can take it back and tell them to take care of it. They can either crack the plug and drain off some or they can do it over. Make 'em do their job right!
boneheads.... Jiffy Lube always trys to pull some crap with "oh, your battery is dead", "oh, your pcv valve is bad", "your air filter is dirty...." and on and on... vultures...
Old May 24, 2012 | 04:33 PM
At least it was only a quart or so, my mom had her oil changed at a shop and they doubled the amount that was required, now THAT can get expensive.
Old May 24, 2012 | 05:07 PM
Marc's Avatar
Ah, actually they do care.
Old May 24, 2012 | 05:31 PM
GreenPhoenix's Avatar
Your lucky they put oil back in it. Best of luck with that drain plug $10 says its either rounded of, stripped out or crossthreaded. DIY
Old May 24, 2012 | 06:30 PM
MaxwellE54's Avatar
Thanks for the replies guy.. well most of them haha.. my engine will probably care. Well based on my oh so accurate description of the oil on my dipstick, does anyone want to take a look at theirs and guess how much she's overfilled? I have a nice little rear main seal leak so if its only a quart ill take that extra five bucks and let it leak over time ha
Old May 24, 2012 | 06:36 PM
rworegon's Avatar
Generally from the low mark to the full mark is about a quart to 1.5qt. Crack the plug and drain some out in a clean container.....re-check and add back some if necessary. Done.
Old May 24, 2012 | 07:12 PM
Teuf's Avatar
Jiffy Lube - catastrophic = failure. solve for Jiffy Lube
Jiffy lube =catastrophic + failure
Old May 24, 2012 | 07:14 PM
rworegon's Avatar
lol, Teuf....that sums it up or, more accurately, solves it up.
Old May 24, 2012 | 07:29 PM
Elton's Avatar
jiffy lube did something wrong lol not a first
Old May 24, 2012 | 07:36 PM
James Woods's Avatar
Ah guys the J-Team aint that bad, I worked there for about 2 weeks, watching guys struggle doing drive belts and laughing at me when I suggested using the torq sticks when rotating tires and tightening the lug nuts in a star pattern, calling the pit guy their "best mechanic"
Old May 24, 2012 | 07:53 PM
Inferno451's Avatar
Correct, they do care. I just meant that if it's only half an inch above the full line (maybe 1/2 quart) it's not going to destroy his engine. I should have specified.
I'd take it back to Jiffy lube and make them fix it, and NEVER GO BACK. First off, it's REALLY expensive for a simple oil change and the only time i went there they forgot to put oil in. You can do it yourself for under $20. I use walmart oil and purolator filters, and can do the whole job in about 10 minutes. Good luck!
Old May 25, 2012 | 04:11 PM
MaxwellE54's Avatar
Cool thanks for all the replies guys. She took the extra oil like a champ and I've been driving her around about 3/4 of a liter over id say. Thanks for the extra 3.50 jiffy lube!
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Coreyr384
Jul 10, 2015 11:13 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
