Product Reviews Post your reviews on automotive and expedition-camping gear here
Stock Head-unit & AMP Wiring = Easy
Old May 13, 2012 | 10:27 AM
osoquik's Avatar
Thumbs up Stock Head-unit & AMP Wiring = Easy
I came across a DIY harness on eBay to make it easy for those wiring up a system to their Factory Head-units. Since, I'm a complete nOOb to wiring up an amp and subs this helped a ton. The harness kit consists of both Male and Female harness pigtails, a inline adjustable converter and butt concerts for the grand total of 12.99 w/ free shipping.
BTW, I have a 2000 4Runner Limited so I installed the harness between the factory amp and actual truck harness with no problems so far.
Factory HU->Factory AMP->DIY Harness->Truck Harness
Let me know if you have any ?s
eBay Seller's Username: autoware302
Link to harness: http://www.ebay.com/itm/220803000155...#ht_4186wt_940
Link to seller: http://myworld.ebay.com/autoware302/...id=p4340.l2559
Old May 24, 2012 | 02:41 PM
MaxwellE54's Avatar
Will this harness also work for aftermarket decks and amps?
Old May 28, 2012 | 03:27 PM
osoquik's Avatar
I'm running a 600watt amp hooked up to two 10 MTXs with my factory hu and amp. But with an aftermarket hu, you can use the the harness that plugs into the truck harness (female end side) & the RCA line convertor, if the aftermarket hu doesnt have rca plug ins. Then just connect the hu harness and run the amp turn on wire to your amp.
Old Jun 1, 2012 | 04:41 PM
87slosohc's Avatar
Yes, and as osoquik suggested go with the Rca pre outs on the back of your deck if it has them.
If it doesn't, you can simply wire in the line level converter to hook up an external amp. The gray and white wires on the one pictured above are spliced into a pair of speaker wires( front or rear depending on which you want the amp to power or rear if you want to power a sub usually). The rca's are ran from the converter to your amp. The converters I generally install have a ground wire that cuts down on feedback through the speakers, you can also add a ground to converters without one.
Your remote turn on wire should be blue with a white line on an aftermarket deck, you want to extend that wire all the way back to your amp. Also try to run it along the same side as your +12V power wire and run the rca's on the opposite side of the vehicle.
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
1994toyota
Jul 17, 2015 03:03 AM
Edionne13
Jul 9, 2015 01:59 PM
