1995 Tacoma EFI Fuse Problem
Old Apr 18, 2012 | 09:29 AM
Whooker23's Avatar
I have 1995 2.7L Tacoma and every once in the while the EFI fuse will blow while I am driving it. I jumped the COR in the diagnosis port and I thought I had it fixed then it blew it again. I replaced the fuse and took the jumper out and it drove for awhile and blew it again. Does anybody have any ideas on what this could be? Suggestions? Thanks.
Old Apr 19, 2012 | 03:08 PM
Whooker23's Avatar
Bump.
Old Apr 21, 2012 | 09:12 PM
Whooker23's Avatar
Help!
Old Apr 21, 2012 | 09:34 PM
tantacoma's Avatar
Originally Posted by Whooker23
Help!
Try replacing the EFI relay. On my 99, the power accessory relay is identical, so it can be used temporarily to troubleshoot.
Old Apr 21, 2012 | 10:34 PM
1994runner's Avatar
check your wiring going to the o2 sensors. sometimes they will rub on the frame or lay on the exhaust causing an intermittent short
Old Apr 29, 2012 | 10:01 AM
Whooker23's Avatar
bump..
Old Apr 29, 2012 | 10:26 AM
rworegon's Avatar
How about telling us what else you've done to track down the problem like checking for bare wires, loose grounds, etc. instead of just bumps and helps?
smthwsn357
May 1, 2024 07:28 AM
rushw
Jul 18, 2015 01:46 PM
Sandman
Jul 14, 2015 12:36 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
dpridgeon3
Jul 9, 2015 01:18 PM
