Sponsored by: CARiD
5VZ-FE swap to 4 Cylinder Engine
Old Apr 15, 2012 | 10:43 PM
TacoTaco97's Avatar
Hello out there. I may need to replace my 5VZ-FE in my 1997 Tacoma 4x4. I was just curious whether or not I could swap out the engine for a 4 cylinder? I would not be doing the work myself, and just wanted to know if anyone here has successfully done this. Thanks for reading this.
Old Apr 15, 2012 | 11:16 PM
wyoming9's Avatar
Red face
Most go the other way I don`t know of anyone who has gone from a 3.4 to a 4 cylinder
What possible motive could you have for doing this???
If your paying to have it done it will be cheaper to fix your engine or replace with what you have in there.
Till you get done finding a 4 cylinder buying that and doing the swap.
Unless someone is doing this that does these kind of swaps it is going to be a learning experience for them and quite expensive
It can be done but for how much is the ????
Old Apr 16, 2012 | 12:53 AM
TacoTaco97's Avatar
Thanks for the reply Wyoming9! Well, I thought I would save money by getting a smaller engine both up front and at the gas pump. But I see your point that it will cost me a lot of $$ for someone to do necessary modifications to make it work.
Old Apr 16, 2012 | 05:22 AM
Texas_Ace's Avatar
Only reason to go with a 4 banger of the V6 is if you plan to turbo it, you can turbo the 4 banger easy.
Otherwise just replace it with another V6. Gas mileage will be about the same or better with the V6 honestly depending on how you drive.
Old Apr 16, 2012 | 11:58 PM
TacoTaco97's Avatar
Thanks TA for the advice. Still waiting to hear back from my mechanic whether I need a new engine or not. I think I will just stick with the V6 engine if it will be less complicated and if there won't be too much benefit to convert it to a 4 cylinder engine.
Old Apr 17, 2012 | 05:14 AM
Greg_Canada's Avatar
LOL it will cost you WAY more to swap a different engine in, rather than rebuilding what you have.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coryc85
Sep 9, 2015 06:24 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
HRDC0R19
Jul 5, 2015 06:43 PM
