Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Radio Dash and Double DIN Radio 1988 4Runner
Old Mar 22, 2012 | 06:51 AM
jorgonzalez's Avatar
Hi, i got my 4Runner for over a year now, doing some restoration on the interior, i cant seem to find the radio dash here in my country, so i looked up for a replacement one over ebay, i just ordered, lets hope it fits, also i would like to know if any of you have installed an aftermarket double din radio, if so tell me wich model fits properly. Thanks
Old Mar 22, 2012 | 06:59 AM
Bassmastry101's Avatar
I've never tried a double din in these trucks but I'm sure you could make it work with a little creativity.
Welcome to yotatech!
Old Mar 22, 2012 | 07:02 AM
Thanks man!
Ok, so its made for single din then?
Old Mar 22, 2012 | 07:10 AM
No problem. Yes, there was a pocket or just a blank plate under the radio. However, If you wanted to I don't see why you couldn't stuff a double din in there.
Old Mar 22, 2012 | 06:13 PM
drpdmazda's Avatar
that truck should accomodate a double din radio with little to no modifications to the outside housing. (the part that has the ash tray in it and surrounds the radio) it will mount using the factory metal radio brackets and should wire up like any other head unit with a toyota harness, minus any brake bypasses you may want to do to get video while driving.
Old Apr 3, 2012 | 11:39 PM
clok's Avatar
I just put a double din dvd player in my 89 4runner , the bottom pocket under the radio was cut out so it would fit in there and used the factory radio brackets, it fit just right.
Old Apr 9, 2012 | 12:30 AM
autoadas's Avatar
it should be univeral double din ,right?
Old Apr 9, 2012 | 09:12 AM
clok's Avatar
Yes I belive so . The side of the radio should have holes were the factory brackets screw into there should be three levels to screw into I think I used the bottom level so it seats centered in the dash but you may have to choose one of the other levels to center yours depending on which radio you choose to get but it will fit , I will post a picture when I get home.
Old Jan 13, 2013 | 01:14 PM
tmcaron's Avatar
Any pictures of the double din? I have been thinking about it but I'm not sure if I want to go touch screen or what. This is what I have as of now.
Old Mar 21, 2013 | 03:16 PM
1quickbabydill's Avatar
a little trimming and home made brackets. works great.
Old Aug 25, 2013 | 11:59 PM
jenniedsy's Avatar
i have been also using 2 din DVD player from happyshoppinglife for one year. it works great and there are no other issues
Old Oct 22, 2013 | 07:01 PM
White88runner's Avatar
It's been years but when I did mine I had to trim the plastic to fit any dash kits
Old Feb 1, 2018 | 02:10 AM
HAMBONE1039's Avatar
I'm not sure as to whether or not a double din would fit inside the opening for an 88, but I know that my 7" fit with a little light sanding and used my dremel around the inside bezel. I also don't have to use any kind of dash kit because my double din bolts right up to the factory radio mounting brackets which makes it kind of nice because that would be a giant pain in the back end to pull that out of there if you weren't supposed to be lol.
ashersullivan88yota
Jan 18, 2022 05:37 PM
mskalmus
May 28, 2017 07:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
smiley52
Jul 11, 2015 05:16 AM
