High Beam Wire, where to tap into?
I decided to rig up my Lightforce 170's using the stock harness until I get my dual battery system installed.
I need to tap into the high beam wire, where and which wire is this?
What year is your Yota? The FSM is available for free download on the site somewhere just do a search for it. I might could help you if it was an 87ish.
Having said that I would HIGHLY recommend that you not run anything else with your headlights as the stock wiring is barely adequate at best. A simple relay running off an inline fuse from the battery would be a MUCH better idea. You could energize the relay with the headlight feed and get the same effect with out melting you harness and having NO lights.
JMHO
JMHO
I tapped into the ignition power wire to the wiper motor so they will not work with the key off but they can be controlled with or without the headlights, I did what worshipmentor said and just used that power to trigger the relay and used a fused wire to the battery for the actual power to the lights.
The way that I found my ignition source voltage was just using my DMM and checking the wires real quick which was faster than looking up the schematic and looking for the wire I wanted.
BTW neib15........
Your headlights in your pic look sick.....literally! If this is what you are dealing with for headlights I dont blame you for wanting something else. I solved this by replacing my stock sealed beams with a pair of Autopal housings and Sylvania Ultra H4 bulbs. I bought both on ebay and spent less than I would have paid for a pair of nasty sealed beams and have TONS of light!
Just my Humble Opinion..........I would recommed that if you do this you look into a secondary harness to drive the headlights too. It is well worth the time/effort/money as the factory headlight harness is barely adequate.
I would just run a jumper off of the high beam wire to the relay, so that way when you hit your bright the bigger lights would turn on as well. If you wire it that way you would use youre bright switch to turn on the lights instead of running another switch....I know I did not answer your question but that is what you are talking about doing correct?
