89 Toyota Pickup front passenger brake locking up
I have a 1989 Toyota Pickup, V6 4wd over 200k miles (overhauled at 189k). I am having a problem with the front passenger brake building up pressure while driving and locking up completely. The brake peddle is stuck and does not budge and will not depress until I let loose the pressure in the caliper. I don't have to press the brake peddle down to let any pressure out. This will happen within 5 miles of driving or dependent on the amount of braking I do.
I have replaced both front calipers, front passenger flex line and the hard line that is connecting to the passenger caliper. I have also bled the lines with fresh brake fluid until I have clean fluid all the way down on all four brakes.
I've seen people saying that the master is at fault or the booster arm is at fault. My dad thinks the load sensing valve is at fault but the rear brakes work fine. I'm debating on overhauling my master to see if it is all gunked up. I do remember that I had some stuff floating around in the reservoir and I'm wondering if it is chunks of something inside the master falling apart.
I want to know any other possible things to look into before I start using up more time and money doing random repairs.
Any Ideas and help will be much appreciated!
Thanks!
Zappy
Thanks!
Zappy
Sounds like a sticking caliper then. I would replace both calipers and hoses. I doubt it would be a problem in the master cylinder simply because a master doesn't direct fluid left to right only front to back.
I understand you have replaced them but getting new parts that are bad isn't uncommon. If you let pressure of it without pressing pedal then thats a sign of a bad brake hose.
6th Gear
19
Dec 10, 2019 07:31 AM
Aleeex_u
Jun 5, 2016 06:52 PM
WTB[International]: 93 P/u fuel door lock, roll bar, hitch, chrome rear bumper
Gamble_STi
Jun 27, 2015 07:54 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
