getting the yota on the road again
i have a 1987 pickup ext cab, 4x4, 22r, 5speed that has been setting for almost 8 years now that my dad gave to me if i want to fix it.
it has a cracked head and 220,000 miles which i know is nothing for these trucks.
i was wondering how i should start the build on it and what all i need to do to it.
just want it for a daily driver due to my broncos 10 mpg, might get off road a little.
any suggestions how i should start and what i should buy first other than a head?
im 17 so i have some but little knowledge on what i need to do to get it running again any help would be appreciated.
thanks
thanks
Congrates on the yota
. Treat her good she take care of ya. You know what I'm talkin about
Well ya other then the head id check fluids in diff, trans, t-case. Depending on budget, change them if there dirty looking. But most likely should just change everything.
Got any pics? Maybe some of the engine compartment. Might help us with suggestions.
These trucks are pretty easy to shine up.
I will post pics as soon as i go to my dads
But do you think if i changed the head and all the fluids and general matinace type stuff she would be good? i was wondering about the sensors and pumps if they would still be in working order
And thanks
And thanks
Once you do get a new head for it. Plan for general tune up, plugs, wires, distributer, oil change, coolant flush, just the obvious. Unless theres anything else wrong with her that should pretty much do it.
Everything there is to know aboot a yota on here.
If its been sitting for 8 years with gas in it then the fuel system will most likely be gummed up. Probably wanna rebuild the carb or at least take it apart and clean it, and drop the gas tank to see how it looks inside.
X2 fuel system.
Brakes could use some inspection also after sitting that long. Calipers could be seized up. But thats somthin to check after you get it running. Mostly just want to make sure their releasing when you let off the brakes.
Jcrawl94
10
Oct 24, 2015 04:34 PM
thzpcs
Oct 3, 2015 07:39 AM
