crankshaft to a/t mounting question
Old Mar 10, 2012 | 10:10 PM
rockthepouch's Avatar
hello all-
I am mating my rebuilt motor up to my '91 4runner auto. I noticed on my new crank (from '03 donor motor) that there is a bearing in the middle...?
Could that be because my donor motor was out of a manual 5 speed?
Here is what the "nub" on my transmission looks like. It seems as though that would go back and fit behind where that bearing is...
When I removed the original motor I didn't see one and it looked as tho those two mated together well.
Here is
Old Mar 10, 2012 | 10:49 PM
infart
Old Mar 11, 2012 | 04:22 AM
Bassmastry101's Avatar
Well it looks like it's time for a manual swap!
The input shaft on a manual slips into the pilot bearing in the end of your crank. Since your bolting it up to a automatic you don't need it. Remove the pilot bearing and the "nub" should slide into it's spot.
Old Mar 11, 2012 | 08:18 AM
dntsdad's Avatar
Are you doing a 3.4 swap into your 91?
Old Mar 11, 2012 | 09:49 AM
DeathCougar's Avatar
That would be a pilot bearing for a manual trans. Remove the pilot bearing, and the converter fills the void when its all bolted together.
You said the motor is from a 2003? So..that means you are doing a 3.4 swap then?
Jun 1, 2021 01:51 PM
coffey50
Jul 28, 2015 10:55 AM
Jonny246
Jul 24, 2015 12:37 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
