crankshaft to a/t mounting question
hello all-
I am mating my rebuilt motor up to my '91 4runner auto. I noticed on my new crank (from '03 donor motor) that there is a bearing in the middle...?
Could that be because my donor motor was out of a manual 5 speed?
Here is what the "nub" on my transmission looks like. It seems as though that would go back and fit behind where that bearing is...
When I removed the original motor I didn't see one and it looked as tho those two mated together well.
Here is
Here is
Well it looks like it's time for a manual swap!
The input shaft on a manual slips into the pilot bearing in the end of your crank. Since your bolting it up to a automatic you don't need it. Remove the pilot bearing and the "nub" should slide into it's spot.
That would be a pilot bearing for a manual trans. Remove the pilot bearing, and the converter fills the void when its all bolted together.
You said the motor is from a 2003? So..that means you are doing a 3.4 swap then?
Jun 1, 2021 01:51 PM
coffey50
Jul 28, 2015 10:55 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
