96 4runner run ruff under load
My 4runner runs fine under normal driving. But you put a load on it and the engine shutters. Like drive up at steep hill or using lots of gas pedal. I already tryed to clean the maf sensor.
I would begin trying to see if you still have the misfire. I'm assuming its a v6 so it may only be running on 5 cylinders but under a load is the only time its really noticeable. I would start by pulling plug wires. If it is in fact misfiring, that could lead you to diagnosis (ie. faulty fuel injector, fouled spark, burnt valve, etc.)
I did the driver side 3 and the rpm lowered with each one. I could only check the rear one on the passenger side because the air cleaner tube is in the way of pulling the wires off.
If I'm not mistaken I believe the cylinders are numbered like this:
5 6
3 4
1 2
Front
So, if I were you I would at least find a way to pull #3 plug wire just to rule it out since its an easy test. Search this forum for an easy way to get to those plug wires. If I happen to run across a good thread I'll post it on here.
5 6
3 4
1 2
Front
Here's what I have found so far.
-primary coil resistance cold .67-1.05 ohms
3-1.3 ohm
2-1.5 ohm
1-1.5 ohm
-secondary coil resistance cold 9.3-16.0 ohms
3-13.84 ohms
2-19.48 ohms
1-12.58 ohms
- compression 145-218
5-155. 6-not done
3-145. 4-not done
1-155. 2-156
I don't do cylinder 4 and 6 because my compression tool was giving me problems.
3-1.3 ohm
2-1.5 ohm
1-1.5 ohm
3-13.84 ohms
2-19.48 ohms
1-12.58 ohms
5-155. 6-not done
3-145. 4-not done
1-155. 2-156
I see you replaced the spark plugs, but you should also replace the wires...this is a classic symptom of bad wires. Also make sure the wires are in their proper clips and not touching any metal surfaces.
I doubt its a coil, since they are paired. The misfire would be in 2 cylinders intermittently if this was the case.
You should have swapped coils to see if the misfire would follow, checking resistances won't tell you the full story. Plus this is way easier, but I see you ordered a coil. Throwing parts at something just costs you money.
Fuel filter is not the issue, a clogged filter will never cause solely one cylinder to misfire.
You could have a fouled plug, so swap a new one in #3 and see if the misfire continues. Just make sure they are double grounded plugs. Vitaly had a good suggestion about it being an injector. I use this Injector Inspector which works really well. Other causes would be a cracked head, pay attention to if it misses more cold or hot. Your compression looks good though from the ones you measured, but do the rest. I don't know if you have access to a descent scan tool to check misfire count at idle, but this would be helpful. Wires would be a good call as well. That's pretty much all your options to cause this issue.
I switch the coil with the number one coil. It runs better but it still spudders under load. Couldn't get the check engine light to come on. I'm going to try and switch the number 3 spark plug when I get home and see what that does.
jennygirl
Nov 17, 2015 11:24 AM
FS[PacSouthWest]: Want To Sell: 1988 Pickup In LA county California
Peach
Jul 3, 2015 09:30 AM
Badger62811
Jun 26, 2015 09:26 PM
