New ARB and Warn M8000 (pic)
Just installed, quite happy
http://www.flickr.com/photos/andrewkumler/6804664550/http://www.flickr.com/photos/andrewkumler/6804664550/ by http://www.flickr.com/people/andrewkumler/, on Flickr
Did you reenforce the end caps of the frame rail before mounting the bumper? I can't remeber if its a issue with the Tacoma but I know the 4runners needed the "end cap" mod to keep the bumper from tearing the frame rail when doing some hard winching.
FOG
FOG
No I didn't. Wasn't aware there was an issue ?
But there were new supports and frame extensions in the kit that I had to fit onto the frame.
The problem is where the ARB bumper brackets mounts bolt the trucks frame. The design of the mount has one bolt going through the frame and on that goes into the front end of the frame rail.
On the 4runner you have to cut the tip of the rail off to mount the bumper and because of that you have to get a thick piece of metal and fit it in the end of the rail and weld it in.
On the Tacoma the end cap is already there but very weak and under heavy winching can pull loose and cause the bolt that goes through the frame to tear the frame rail in half.
(Tacoma end caps)
The factory end caps on the Tacoma were not designed for pull the weight of the vehicle or another if your trying to winch someone out.
(Broken end cap)
The way to fix this is using a piece of thick steel as shown on http://www.nwtoys.com/content/123-fr...ification.html
(End cap mod)
With end reenforced with the above mod you can perform some HEAVY winching without the issue of frame damage.
FOG
(Tacoma end caps)
(Broken end cap)
(End cap mod)
FOG
Well that was nice of ARB to tell me. What a crock
Thanks for the info though
Although there is more than one mounting bolt on mine. I had to drill a hole up through the bottom of the frame and a bolt and metal sleeve fit up through connecting the mounting brackets . I wonder if that is a newer addition for that problem
really want to get a M8000 installed in my ARB somedayas far as end caps go I would get in done just for peace of mind.
End Cap Mod
For anyone interested, I contacted ARB and they said that they modified the mount design last year(2011) to incorporate a double pinning into the frame. This means there is no modification to the frame needed for rigs that will be doing hard winching.
Think of a paper towel roll and sticking bolts through the top and sides of it to transfer a pulling force. Whats going to happen is the bolts are going to slowly rip through the tube because of the little surface area the bolts are transferring force to.
The proper way is to put the majority of load on the end of the tube (end cap mod) because it is able to put the load on every inch of the top, bottom and both sides of the frame tube.
What ARB is trying to do is keep their bumper a "no welding just bolt on" bumper because welding makes allot of people queasy. But the bottom line is Toyota never intended for a winch bumper to go on them so welding is a necessary evil IMHO.
FOG
Your 'bumperettes' are upside down. I believe that reduces your winching capability by 20-30%.
This is what my truck looked like before I put my ARB on, notice there are end caps there, which I did have to trim the lip on a few sides to get the bumper to slide on, but no bolt that goes through, as listed here; http://www.nwtoys.com/content/123-fr...ification.html
What does that do? Why don't I have one?
The ARB bumper was not "designed" for the 4runner only the Tacoma and if you notice on ARB's web page and catalog they don't spec a bumper for the 4runner 3rd gen.
The reason is the Tacoma has a "end cap" with a bolt hole. The end cap isn't very strong but it has one. The 4runner doesn't have a end cap like the Tacoma does so you can't use it to mount the bumper.
What you have to do is get a grinder with a cut off wheel and cut the welds that hold the cap on the end of the frame rail off. Then you will have a open frame rail and you can build a end cap as per the "end cap mod" link you show above. Then you can bolt the bumper on and it will be strong as a OX.
FOG
FOG
Ya or just weld the ----er on their.
Its a bumper. People build them. Cant be that hard to mount one to the frame.
Good alternative to trying to find a taco in the junk yard. Just get some plate steel and make a mount.
got my ARB off a buddies truck that he rolled and totaled. A few late nights at work with the torch and hammer had it straightened back out then had it re-powdercoated. AS far as mounts I made my own from 4in channel iron and heavy angle. ( the ones from the wrecked truck weren't salvageable) Gunna just weld mine solid to the frame tho that way I shouldn't have any worries
