First run. Maybe went a little too big :(
Old Mar 3, 2012 | 03:35 PM
UsaTuff's Avatar
Unhappy First run. Maybe went a little too big :(
I got my 1994 Toyota Pickup DLX finally finished. A solid 1500 on the new motor, which is a 3vze. Anyway, I went out today and played with some friends in the mud. I was the only one to attempt this pit and paid the price.
Long story short, it's making a terrible noise. When stuck in the pit the truck shut off and barely got it started back up. I'm thinking water got in the pan and I may have spun a bearing. The truck can't get to 3000 RPMs and is making what may be a knocking noise. Anyone else been in this situation please tell me what ended up happening. I will most likely be pulling the motor, again
Old Mar 3, 2012 | 03:38 PM
RogueYota's Avatar
Its got a 3vz...thats what happened lol
Yeah you most likely sucked up alot of water...maybe bent a rod...got water in the pan like you said...screwed something electrical up...it could be a number of things...but it sounds done for from your description.
Old Mar 3, 2012 | 03:44 PM
UsaTuff's Avatar
Well I can say I popped the hood, no water in the air box, oil is a little thinned out but not super runny
Old Mar 3, 2012 | 03:51 PM
RogueYota's Avatar
You'd be surprised at how little it takes.....but the oil may have thinned out enough to where it spun a bearing. But if it died right away I dont see it...but if you sat there at limiter trying to get out I could. Sounds like a spun bearing....they usually sound more like a squeaking chirping type noise rather than a full on knock.
Old Mar 3, 2012 | 03:56 PM
rworegon's Avatar
I fail to see the fascination with mud holes......
Old Mar 3, 2012 | 03:59 PM
RogueYota's Avatar
Yeah me too....im not a mud fan at all.
Old Mar 3, 2012 | 04:00 PM
UsaTuff's Avatar
A few bigger trucks went through it but no one else wanted to. Didn't seem to deep at first till I made it bout 3/4 of the way through. The truck didn't instantly shut off. It was idling and I got out to get my chain and the idle got lower but not fast until it finally stalled I. But it did start right back up
ThatGuy1295's Avatar
Did barbie try it? Or the 2WD dakota?
Old Mar 3, 2012 | 04:01 PM
250000_yota's Avatar
I agree fully. Judging by the last pic, it looks as if you probably either had a fair amount of speed, or a good amount of weight on your skinny pedal, by the distance into that hole your truck is.
Regaurdless, it sucks to hear that you put the time and effort into a new motor just to have to "probably" start all over at the beginning. Unfortunately, we all have to learn the hard way from time to time...
Old Mar 3, 2012 | 04:07 PM
Ya happined to me once. I heard gurgling and shut it off right away. Then winched it out with the motor off. No damage occurred.
Hopfully its somthin simple and cheap, but doesn't sound like it.
Old Mar 3, 2012 | 04:10 PM
rworegon's Avatar
I'm curious.... How does the water from the mud pit thin out the oil if your intake was dry? What is the path of entry for the water to the oil?
I'm scratching my old head trying to figure this out.
Old Mar 3, 2012 | 04:12 PM
__________________
X2 on that... Aperently I may not have enough holes in my motor.
Old Mar 3, 2012 | 04:16 PM
UsaTuff's Avatar
I got the furthest anyone has gotten while still getting stuck... I'm not sure if that is an achievement I want
My friend has the same style gasket I am using, the cork style. He drove through a pit like this and it got through the gasket. I have heard nothing but bad things about this gasket and believe it may have helped with the problem. But the filter was dry and the same with the intake pipes.
Old Mar 3, 2012 | 04:18 PM
rworegon's Avatar
Even if the intake was wet, I cannot see how the muddy water thins the oil.
Well, if the cork fails you have a point....use Toyota FIPG on the oil and more cork to fail.
Old Mar 3, 2012 | 04:20 PM
RogueYota's Avatar
OK well if water didn't get in there then you just had it pinned and something gave. Just cause the motor is rebuilt doesn't make it invisible but if no water got in the motor through the intake I have a hard time thinking that water had enough time to soak through a cork gasket.....get enough in the oil....spin a bearing at idle...then die. But hey....crazier things have happened right?
Old Mar 3, 2012 | 04:22 PM
I dunno. But I treated this thing like a boat and didn't kill it. Lots deeper then this most of the time. Up to the headlights very often. Maybe you were going faster and had more splashing. But that shouldn't have killed your truck. Unless you have an open air box or somthin.
Old Mar 3, 2012 | 04:32 PM
UsaTuff's Avatar
No one else tried it. There was the blue 89 YJ, the red 97 dakota (which is 4wd) and another Jeep that isn't there. It took the 2 Jeeps to pull me out. I was stuck good.
Old Mar 3, 2012 | 04:34 PM
UsaTuff's Avatar
Not tryin to knock ya or anything but I have horrible experience with the 3vze but keep wanting to try it... Mainly because the 350 swap is too much money and I can't find a decently priced 3.4 around me neither. I'm gonna pull the plugs and drain the oil in the morning. Pu new oil in, check the plugs and see what happens. See if it is worth trying to start it.
Old Mar 3, 2012 | 04:38 PM
rworegon's Avatar
Be sure the cylinders are clear of water/oil when you have the plugs out.
Good luck.
Old Mar 3, 2012 | 04:39 PM
UsaTuff's Avatar
Thanks
