First run. Maybe went a little too big :(
Old Mar 8, 2012 | 10:46 PM
  #41
racerflea's Avatar
Dude if u had to replace ALL the of that stuff from one trip u were overlooking alot of stuff before u got stuck
Old Mar 9, 2012 | 05:44 AM
  #42
mpwarfy's Avatar
Probably so but there was never a leak before and no rear end noise before that day
Old Mar 9, 2012 | 06:08 AM
  #43
Bassmastry101's Avatar
The seals were probably on their way out the door when you hit the puddle. Hitting it just made you see what needed to be replaced.
Old Mar 9, 2012 | 06:17 AM
  #44
mpwarfy's Avatar
Lucky me! It's just easier to blame that puddle for all the problems and my daughter for suggesting we go through it.
Old Mar 9, 2012 | 06:26 AM
  #45
xxxtreme22r's Avatar
I agree, the engine wasn't rebuilt properly. Probably failed to have the crank checked and/or re-ground.
Originally Posted by xxxtreme22r
And the video.
This is a combo of 4 lo 1st, 4 lo second and 4 lo reverse at 5,000-5,500 rpm.
The launch was at 3,000 and you can kinda hear me hit the rev limiter. Yes rev limiter on the carb'd truck. I have the limiter set at 5750.
This for all you guys who really wanna see me hammer on this engine, hear my exhaust note and why I want that electric fan. :great
I ran 4 times throughout the day got further each time.
http://www.youtube.com/watch?v=UPmKquvXor0
And this is what my engine bay looked like afterwards.
Old Mar 9, 2012 | 06:35 AM
  #46
mpwarfy's Avatar
Holy crap man my rig would have blown up
Old Mar 9, 2012 | 06:38 AM
  #47
Only thing that stopped me was the fact the engine temp hit red line. Due to the high rpm and low air flow over the rad coupled with the mud.
Rebuilt by myself, about 10-12k on the engine at that time using new crank and rods.
Old Mar 9, 2012 | 06:39 AM
  #48
James Woods's Avatar
Originally Posted by UsaTuff
Long story short, it's making a terrible noise. When stuck in the pit the truck shut off and barely got it started back up. I'm thinking water got in the pan and I may have spun a bearing. The truck can't get to 3000 RPMs and is making what may be a knocking noise. Anyone else been in this situation please tell me what ended up happening. I will most likely be pulling the motor, again
All 4 tires are new
Oh ok, I was just looking at those front tires and I guess they just didn't clear at all because they look bald in that pic.
Also all the talk about pan gaskets, doesn't Toyota say to use fpig on the pan, which is in my opinion way better than any gasket when properly applied.
Old Mar 9, 2012 | 08:13 AM
  #49
ThatGuy1295's Avatar
Oh gees... oh well
Old Mar 9, 2012 | 09:14 PM
  #50
UsaTuff's Avatar
The engine was rebuilt properly. I had gotten the truck from the original owner who had never replaced the motor. The motor had 150k on it and he only changed 3 pistons in the motor. My and my dad spent weeks plastigauging and torquing and retorquing everything on this motor. Te crank was overlooked because I didn't think anything over it. The whole reason I built the motor was because it blew a head gasket and I wanted to see if I could squeeze a smidge bit more power out of it.
Old Mar 9, 2012 | 10:03 PM
  #51
How many miles were put on it after the "rebuild"?
Old Mar 10, 2012 | 03:08 PM
  #52
UsaTuff's Avatar
1,309 miles.
Old Mar 10, 2012 | 05:02 PM
  #53
benski8's Avatar
Hey cool Foxhead on the hood of the truck photo in #10 Permalink. I wonder how many people even notice it?
Old Mar 10, 2012 | 07:56 PM
  #54
UsaTuff's Avatar
Originally Posted by benski8
Hey cool Foxhead on the hood. I wonder how many people even notice it.
Who has a fox's head?
Old Mar 12, 2012 | 04:04 AM
  #55
Originally Posted by ThatGuy1295
I think he means this.
Old Mar 12, 2012 | 06:30 AM
  #56
racerflea's Avatar
Didnt catch that 1st time
Old Mar 12, 2012 | 06:56 AM
  #57
photoguy2354's Avatar
From: Currently Virginia Beach, Va. Hopefully back to Wa. within the year...
Originally Posted by rworegon
I fail to see the fascination with mud holes......
Agreed. However mud without the pond on top of it is fun as heck.
Sorry to hear about your failed celebration of a completed build. That bites big time!!!!!
Old Mar 12, 2012 | 04:40 PM
  #58
UsaTuff's Avatar
Well looking at 5-6 days of down time. Dropped off the crank today to get cut, which my shop said it'll take about 2 days. The bearings will take a few day to arrive. Then just gotta drop it back in. Total of $ 175 for the crank and bearings
Old Mar 12, 2012 | 04:43 PM
  #59
1300 miles on an improperly rebuilt engine? Why are you driving through mud holes and romping on an engine? I would hope your tossing a new set of rings, and having those cyl walls checked as well. And not just hitting them with a hone tool. You never mentioned what you had done with the cyl walls.
Old Mar 14, 2012 | 07:25 PM
  #60
UsaTuff's Avatar
1300 miles on a PROPERLY built motor. The only thing overlooked was the crank. I was not romping on the motor as it never went over 4k in RPMs. 1000 miles is what i break all my motors in at. conventional oil change every 250 miles, which always came out clean. Block was hot tanked, bored .50 over, new rings, pistons, rods and the block was decked. Heads have been decked and tanked too along with the plenum and upper intake. There is a whole build thread on it.
Crank is at the machine shop. I never replaced the crank on the rebuild. Turns out the crank was worn down to it's last leg. He had to go over .0300 which is the max for the bearings. He is now welding the crank and then gonna grind it back to stock spec.
