1981 toyota 4x4 20r22r hybrid
no photos at this point. The truck was a gift. the engine was bad. and the head was trashed. after picking a head outa the junk yard haveing it surfaced and the valve seats checked it was ready to go on. the block cleaned up 60 over and installed new rod and main bearings along with the new pistons and rings i put the head on and used the 20 r intake with a weber 32/26 carb. eliminated the vacuum and emmisions, leaving the only vacuum lines the distributor lines. there was some small mods that had to be done for the throttle cable and mounting. also blocked off the egr. the coolant lines were a little tricky trying to figure out correct flow. there are two lines the one in the middle of the head that i hooked up to the line to the timing cover and hooked my heater core to the top of the intake. i also looped the extra return and vent tubes for the fuel tank together. these mods were completely worth it has more power than any of my other toyota 22re. this is my 3rd toyota from the 80s and im ready to take to the hills.
Jun 1, 2021 01:51 PM
