Fried Instrument Cluster?
Hey, I have a 1998 and I was changing my dash lights and replacing them with LED's again... when I saw a blue spark when installing a new led. The
cig lighter, a/c control and tranny indicator lights and dash lights are all dead including the buzzer sound when the door is open and the headlights are on. I checked the fuses and they seem ok...When I turn the headlight switch on none of the dash lights work.
My turn signals still work as well as the warning lights. My map lights, and dome lights work as well but nothing else.
What do I do?? ( yes I made the foolish mistake of leaving the battery plugged )
Are you sure the fuse is good? Try swapping the fuse with known good one, sometimes they look good but are bad.
Hard way to learn to always disconnect the battery when working on electrical stuff.
I'm gonna try to swap the fuses with a known good one now.. if that doesn't work. whats next to try?
Get a wire diagram and start checking for power and ground, I am not sure if it has a fusible link at all for that system, should be in the wire diagram but that could also be your cause.
Thanks for your help tho, it sucks when bad things happen and you have no one to ask for help.
TheBFA
Feb 15, 2020 06:55 AM
