tightening alternator belt
Old Jan 29, 2012 | 06:45 PM
RatLabGuy's Avatar
Any magic tricks folks have found to getting the alternator belt tight on a 22re?
e.g. a particular place to use as a leverage point or nifty home-made tool to ease pulling it outward while maintaining a free hand to tighten the top bolt?
I'm failing to find a good access for this but I'm sure I'm overlooking something.
Old Jan 29, 2012 | 06:47 PM
sebastianholmes's Avatar
i used like a 2 foot long 3/8 ratchet extension put it over the alternator and hooked it on something then pried it tight and tightened the bolt
Old Jan 29, 2012 | 06:52 PM
T_F_E's Avatar
Ratchet strap
Old Jan 29, 2012 | 08:01 PM
A2theK's Avatar
x2 on the 2 foot extension. I braced it against a spot on the timing cover where it wouldnt move around too much and worked like a charm.
Old Jan 30, 2012 | 03:48 AM
rustypigeon's Avatar
I just use a pair of adjustable joint pliers that can open their jaws wide. I tighten the adjustment bolt on the alternator just enough to that when I move it with the pliers, it will stay put. Then I put one pair of pliers jaws on the bolt, and the other on the end of the bracket. Then just tighten the pliers.
shooter86314
Jan 7, 2016 07:05 AM
Zach_trun
Nov 17, 2015 07:56 AM
JUICE222
Oct 13, 2015 08:50 AM
mbomberz1
Oct 9, 2015 07:17 PM
SCZIG
Sep 20, 2015 09:00 AM
