General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Charging Challenge ??
Old Jan 28, 2012 | 08:39 AM
wyoming9's Avatar
Red face Charging Challenge ??
New vehicle to me. 87 4Runner 22REC manual
Multimeter tests
Engine running !! voltage at battery @ 12 VDC with headlights and blower on high drops to just under 12 VDC
Dash lights not on no Charge light or Battery light
All the fusible links have been tested for continuity as well as all the fuses to tell the truth I just put all new fuses in just to be safe.
I also swapped in a working alternator off a running vehicle as well as a new battery up graded the ground cables. New Battery terminals as well
The volt meter on the dash is not working as well as no charge light or the brake light Check engine light I am not real sure. I am thinking a corrosion problem perhaps in the left side in cab fuse block.
My next step is to pull that off after that check for voltage at the alternator plug
Back to the drawing board:jessica:
Old Jan 28, 2012 | 10:42 AM
swampfox's Avatar
In the fuse box Under there is a 7.5 amp fuse ,if it is good try jumping 12v to it with the motor running. If the charging system starts working the charge light bulb is bad. At least that is a quick test for a truck without the volt meter,it might still work. It should charge untill the motor is shut off.
Old Jan 31, 2012 | 10:26 AM
wyoming9's Avatar
Red face
Not to leave you all hanging but it was a dirty connection that took all of 10 minutes to find and fix once I knew which Fuse to look at.
It sucks now that Toyota sold the Service Manuals to Helm Inc a former $15.00 electrical manual is now $60.00 and people complained about the $15.00 price.
To me this is the only manual I will buy
justdifferentials
14
Jun 11, 2017 08:36 PM
Chicken12
Oct 14, 2015 03:54 PM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
SCZIG
Sep 20, 2015 09:00 AM
