'89 interior wiring diagram help
Hi all am in need of some help getting my brothers ’89 4x4 v-6 std pickup back to driving status after setting in his pasture for the last 12 yrs.
What I need is an interior/under dash wiring diagram. From left to right side kick panels.
We got it running, have redone the clutch and brake hydraulics, and ran into a problem with the gauge fuse blowing.
Had a wire smoke a little on the back of the interior fuse box coming off the relay integration module on the 3rd fuse. Black with a brown stripe wire.
That wire splits into several same colored wires that run to several places across the dash then to a relay mounted on the right side behind/above the kick panel.
I’ve been unable or in the interior.(other than the one noted)
Without knowing what that wire is supposed to do and what all it goes too I can’t put it back together and have the gauges working.
All he has is a Haynes manual and of course it doesn’t have the interior wiring diagram.
Or maybe some info from someone that has had problem with relay integration module, or knows what the relay I'm talking about goes to, or that knows what black with a brown stripe wire I'm talking about.
I haven’t been able to locate one online so, I’m asking if anyone has the Toyota factory wiring manual that can post me a link or email me a copy it would be much appreciated.
Thanks
Jay
Thanks
Jay
montanatruck
Feb 26, 2017 07:07 AM
88yodabasket
Jul 13, 2015 01:32 PM
