Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
plasma cutter
Old Jan 26, 2012 | 05:18 AM
jontoptek's Avatar
plasma cutter
what would be a nice entry level plasma cutter?
Old Jan 29, 2012 | 03:17 AM
wyoming9's Avatar
Red face
About like what would be a good first vehicle!!
It all comes down to what types and thickness of materials you want to cut???
Then your budget comes into play!! Do you have a good enough supply of clean dry air.
You can`t go wrong with the latest models from Hypertherm or Thermal Dynamics .
I would sit down and figure your needs then do your home work.:jessica:
Old Jan 29, 2012 | 04:43 AM
Swimmerboy2112's Avatar
I agree with wyoming09,
You need to figure out what you need first.
12Amps? 25Amps? 40Amps? 50Amps? More?
The general rule of thumb is 100Amps is equal to 1" of cutting power.
Therefore, If you need to cut material that is 1/2" thick, you'd use a 50Amp or greater machine.
About clean air, HAVE IT! Dirty and/or wet air is a major cause of machine failure with these plasma cutters. Do yourself a favor and get a filter.
I fix welders and plasma cutters for a living. I prefer Hypertherm over all others.
The Powermax 30 is a nice little unit, small and compact. Plus you get a 3yr warranty.
Hope this helps! Feel free to PM me if you have any more questions!
-Brian
LosPatosDelSur
23
Mar 12, 2021 03:08 AM
skoti89
Apr 30, 2016 10:44 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
BigA
Mar 20, 2006 09:33 AM
abrogate
Oct 4, 2005 12:22 PM
