94 4x4 12" lift-4WD doesn't work
Ok so i have a 1994 toyota lifted 12" on 37s manual lock hubs but when i go to shift into 4x4 i get nothing but the light my light comes on but its not engageing. Iv tried locking the hubs then tried them unlocked i just cant figure out whats goin on. can anyone help me find my problem. please and thank you.
ok for some reason im having trouble logging in. but for now the truck is IFS its only a massive mall crawler i dont go in the mud or hit the trails anymore. but i checked to make sure the hubs lock all the way and they do. there is a transfer case test i forgot how its done but i did it like the guy said and transfer case is good only thing i can find is maybe i need new hubs they are still the stock hubs from factory. also i tried to upload a picture but i couldnt get it to do it. so if you have any other ideas for finding the problem with my 4x4 please let me know.
Well its either your hubs, differential or transfer case. If they were all good, then it should work. I think you need to re check everything.
Check to make sure the hubs are engaging, not just that the dial is in the "lock" position. Jack the wheel up, lock it in, then check to see that its locked to the cv shaft. Do the same for both sides.Once that good, keep moving up the chain.
ok yes driveshaft spins im gonna try rattlewaggons idea when its day light and i cant figure out how to post pics its not to bad top heavy i drive it daily it has almost 15 grand put into it i have all recipts bought it this way but now im wanting to make it a show truck its just a mall crawler right now but thanks rattle if that works and hubs are good whats the next test i should run and how to do it please?
Easy check is to put the front tires up in the air and then you can spin all the parts as see what is up. I think you said you have manual hubs, so lock them, t-case in 2H and then spin the front drive shaft and see if either CV axle turns. If so, and the wheel attached to that CV does not spin, then that hub is acting up. Might be simply assembled incorrectly, which is easy to do.
And you can also try turning either CV axle and see if the shaft turns and you can also test the hubs by seeing if the wheel turns if you turn the CV axle.
Best bet is if the Aisin hubs are acting up, rebuild them. They are better than the Warns, won't cost you anything and it is easy to work on them. Some links below:
- http://www.4crawler.com/4x4/CheapTri...ld.shtml#Links
