good protective oil for fresh 22re's?
Old Nov 25, 2011 | 01:19 PM
jeetS's Avatar
I read through a massive thread about oils and the need for adequate zddp and have started using rotella T6. The thing is its a 5w40 and my truck only has about 10k miles on it and I find the 40 weight a bit heavy for my climate (vancouver, BC)
Anyone know of a good protective oil (like the T6) that's maybe a 5w30?
I like Full synthetic especially as the oil is peing pumped through a turbo
Thanks
Old Nov 25, 2011 | 02:36 PM
DJ99's Avatar
If you want to stick with Shell products, they make a Formula Shell full synthetic 5w30. Rotella T6 is made for diesel applications. If you go the synthetic 5w30 route, then you could probably choose most any brand, IMHO.
Old Nov 25, 2011 | 04:59 PM
jeetS's Avatar
The diesel application is good because it has high zddp. most oils do not have high zddp that is required for these high pressure valve tappets/rockers…
If you read my first post I'm looking for oil that has adequate ZDDP
Old Nov 25, 2011 | 05:25 PM
SCToy's Avatar
I just run Mobil 1 5w30, when I tore it down nothing looked scarred or scratched. No deposits of junk in either. Just my opinion, but I've been happy with it so far.
Old Nov 25, 2011 | 05:47 PM
Squeebs's Avatar
I wonder what is so great about zddp compared to the molybdenum found in newer synthetics?
Old Nov 25, 2011 | 07:26 PM
DJ99's Avatar
I don't know why I didn't think of this before, but the Shell Rotella T5 10w30 would work for you, and it has a lot of ZDDP in it.
Old Nov 26, 2011 | 02:18 AM
wyoming9's Avatar
Wink
I didn`t think it got all that cold up there in Vancouver .
I run 20/50 Castrol all year round but it only gets below zero for a few days at a time.
Old Nov 26, 2011 | 06:33 AM
Marc's Avatar
I don't think there is any difference between 5W30 and 5W40 as far as cold weather performance goes.
Old Nov 26, 2011 | 07:29 AM
blakefogt's Avatar
no issues when i used to run valvoline vr1.. also ran that in my VW racing engines.
Old Nov 26, 2011 | 09:59 AM
jeetS's Avatar
i was mostly concerned with the fuel mileage…I noticed a pretty big drop when I switched and my engined pretty tight so the 40 isn't of any benefit
Ill check out the T5 thanks
Old Nov 26, 2011 | 09:59 PM
94toy22re's Avatar
i run rotella t6 in everything lawn mower, 15.5k redline 600cc bike, 2 22r/22re trucks and a fj cruiser with no problems all year round.
Old Nov 26, 2011 | 10:23 PM
4wd4fun's Avatar
why is 5w40 too heavy for you?
it's a 5 when the engines cold and 40w when the oil and engine is warmed up.
if it gets too cold out you may need a 0w40 or something even stranger.
Old Nov 26, 2011 | 10:33 PM
jeetS's Avatar
Originally Posted by jeetS
i was mostly concerned with the fuel mileage…I noticed a pretty big drop when I switched and my engines pretty tight so the 40 isn't of any benefit
Old Nov 26, 2011 | 11:05 PM
4wd4fun's Avatar
Rotella has a 0w30 if you didn't know.
So, the turbo may like the 40 better than a 30.
Old Nov 26, 2011 | 11:12 PM
4wd4fun's Avatar
So is it a 22RE or is it a 22RET/22RTE or a turbo'd 22RE?
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coryc85
Sep 9, 2015 06:24 AM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
