Clutch start cancel switch removal
Old Nov 22, 2011 | 12:18 PM
chnkymnky's Avatar
Does anyone know where the wires go for the clutch start cancel switch? Would I have to pull my dash apart to remove them all (other than the bottom part of the dash to get the switch out...)?
Thanks!
Old Nov 22, 2011 | 03:12 PM
bryce_dielman's Avatar
theres like 4 screws holding on the piece that goes over the dash cluster and you can pull it off and the switch is right there hope it helps
Old Nov 22, 2011 | 03:58 PM
Teuf's Avatar
Remove the clutch actuated switch. Then bridge the unplugged end.
Old Nov 22, 2011 | 04:18 PM
Inferno451's Avatar
^^^^What he said^^^^. Beat me to it. One of the first things i did to my truck along with gluing down the key release button. Best mods so far. Plus, free is good.
Old Nov 22, 2011 | 04:21 PM
chnkymnky's Avatar
Where's the clutch actuated switch? I've got the clutch start cancel switch removed from my old truck - it plugs into a plug w/ a three wire connector in the dash.
Turns out my new truck has the same plug behind the block off plate - if I'm lucky, the electrical is already there and it just needs the switch to work...which I'll put in in a few minutes...
Thanks!
Old Nov 22, 2011 | 04:25 PM
Inferno451's Avatar
chnky-
The clutch switch is down in the pedal assembly. If you go down there and push the clutch pedal in, you can see it hit the white button on the left side of the switch in the picture posted. It it's not there, you can either reinstall that switch or jump the 2 terminals in the connector for your nonexistant clutch switch.
Old Nov 22, 2011 | 04:55 PM
dntsdad's Avatar
just pull the switch from the dash and jump the plug. Should take about 10 seconds.
Take the switch and send to me. Done
Old Dec 2, 2011 | 01:47 PM
chnkymnky's Avatar
Thanks!
Old Dec 2, 2011 | 01:48 PM
bob200587's Avatar
Why would you want to remove that?
It's incredibly handy.
Old Dec 2, 2011 | 01:50 PM
chnkymnky's Avatar
I'll be taking out of my '87 that's going to the scrapyard to use in my '86 that I'm keeping...
Old Dec 2, 2011 | 01:57 PM
bob200587's Avatar
Well that makes sense.
Old Dec 2, 2011 | 04:24 PM
James Woods's Avatar
I was thinking the same thing at first and then I saw that he is putting it in another truck, I use mine every morning and I love it.
Old Dec 2, 2011 | 06:57 PM
Teuf's Avatar
I took that switch out thinking it was my starting problem. come to find out it was mt starter. I never put it back in. that was 4 years ago.
Old May 18, 2016 | 07:51 AM
frzr's Avatar
How do you disconnect the switch from the wiring? I thought it would be your typical electrical "squeeze tabs" to release the Clutch Start Cancel button, but mine wouldn't budge at all.. do you have to cut the wires or something?!
Old May 18, 2016 | 11:34 AM
Teuf's Avatar
Scroll back on this page and see the foot switch...... Just remove that and then join wires coming out of the floor there....
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
jjrbus
Jun 27, 2015 12:56 PM
Yoda
7
Jun 22, 2002 07:14 AM
