6 1/2 plow, 92 p/u 22re. can it handle it??
I was wondering if my 1992 yota 4x4 22re manual lockouts can handle a 6 1/2 plow?? What can I do low cost to help it....I'm gunna use it for a plowing areas Where I can't get my big truck in, which is about 5 or 6 small jobs. It's gunna have to carry it every snow fall about 30 miles and back. Also how much weight eem I gunna need in the back? Any info would help greatly.
Thanks in advance
Thanks in advance
The worst part is going to be the 30 mile commute to the jobs. These trucks handle like pregnant water buffalo`s with a plow on. Would it be possible to keep it any where close to the area to be plowed.
Weight I am not sure I would say a good 500 to 600 pounds You could get a few of those sand bags put right over the rear axle. I just kept throwing steel scrap in the back of mine .
As long as you are doing the plowing and take your time you should have no mechanical problems.
If you have plowed snow long enough you know things are going to break.
I would guess a skid steer and a trailer is out of the question
My Pops plows with his '83 22r and doesn't have problems. Granted he only plows our paved road and rarely drives further then the nearest gas station.
The front is sitting on the bump stops, so don't expect a comfortable ride.
kbpickens
Oct 2, 2015 03:37 PM
Odin
Sep 26, 2015 06:56 PM
