More 3.slow headgasket questions
Hi everyone
My last main thread about my headgasket was here : https://www.yotatech.com/forums/f116...tumped-241306/
feel free to read it if you have nothing better to do.
Well i got the heads off today, turns out cylinder 1 is the culprit.
Quick question. There is one coolant passage on block that seems "blocked off". All the coolant passages on the headgaskets seem all there but theres a passage on the block that doesnt go thru.
Heres a pic, its the passage on the bottom right.
Not sure if its supposed to be blocked? But thats where the gasket failed, and let water/coolant into the combustion chamber.
Also why dont all the coolant passages on the headgasket have the same dimensions as the coolant passages on the block/head? Most all the coolant passages on the headgasket only have a small hole as a passage and the rest is blocked off, like this
thanks in advance for your help
Flying91
45
Apr 11, 2024 04:39 PM
defrag4
Jul 31, 2015 10:50 AM
