Rear Diff.... HELP!!
My thoughts exactly.. I'm multi-tasking... got auto parts stores up on the laptop and this thread up on the cell.. finally read Wabbit's reply and I got a few more after that. thanks a bunch...
Now what parts do I need? I may not be the most mechanically inclined, but I can figure things out... just trying to look up replacement parts and can't figure it out...
so pretty much what I'm gonna need is...
http://www.autozone.com/autozone/par...mString=search
and some rented tools??
Get a 6 sided socket, not a more common 12 sided socket to remove the fill then drian plugs. A 6 sided socket will prevent you from rounding the corners on the fill plug.
I use a 24mm on my 1999 4runner.
OK well I'll start there. Definitely cheaper than a $200 seal set. I'll drain it, clean it up, seal it, refill it, pray that's the problem.
135,000 miles and the rear diff hasn't been touched anyway... shame on me..
Thank you thank you
Thank you thank you
ok ok ok fine fine fine enough standing around at the tail gate talking about it... I'll jack her up and take a look....
Socket is $6
Ratchet is $20
FIPG is $13.70
New diff fluid $??
Socket is $6
Ratchet is $20
FIPG is $13.70
New diff fluid $??
guess I gotta buy one.. and a 1/2" drive ratchet... bummer
