88 toy LC eng. Engine (longtravel susp.)
i got a 88 toyota pick up. Bought it for 2k, got stationed in cali so made the long drive from Texas to here and lasted about 2 months here and the motor threw a rod I'm guessing..
any way i have a long travel kit in the front .pretty much a Total Chaos kit just "homemade" i don't know the total travel number.
just bought this LC engineering motor a week ago and its going in the truck tomorrow. should be lots of fun!
plans are slowly make it a pre runner . a fun toy to play in the sand with
on to some pictures..
(yes tires have crazy positive camber...its not aligned or anything ..no shims at all on the uppers)and pics are in reverse order sorry
yea the pictures are definitely backwards..
lol.
You should check out the thread guidelines for build up, though. It's at the top of the build up threads.
They try to keep all the titles similar.
"Only additional rule in here is the thread title...
"_username_ _year_ _model_ Build-Up Thread"
example
"Fink's 1985 4Runner Build-Up Thread"
This will make it 10x easier to search and find the build you want to look at."
-Fink
lol.
example
-Fink
sorry about the title ....how do i change it ? to green97nissans 88 toyota pickup?
and its out now! and he would have gave me hell for it but they don't give us any covered storage area so what was i suppose to do ...i know a few people who bring their street bikes in when it rains lol
dam if u spent that much money on the motor id just find a early toyota 4x4 to throw it into screw the pre runner stuff ive rolled with two wheel drive it sucks after a while when the stock 4x4s are wooping you lol
motor is a 22r block with 20r heads port and polished stage 5 cam forged high compression pistons forged rods steel crank titanium valves dual rate valve springs dual side draft webbers, dual msd ignition and msd distributor, billet alum. water pump ted clutch and fly wheel ....
and LC header
2500 dollhairs$
and LC header
2500 dollhairs$
i need to save some money to do the back since they don't have a welding shop on base to do our own welding and fabricating so it will be a little while.
but the plans are to do a simple set up ..Deaver leafs with a shock (idk what i want to run yet) and the total chaos 12" shackle .
not all wired up and still need to drain fuel tank, i wanna coat it with that stuff from auto zone so theres no contaminants in there, add fuel pump, better filter, regulator, all the fluids and throttle i need to figure that out ..idk how it goes yet
how much are you wanting to spend on shocks? lol ive been researching so ill share, the bilstein 5100's through 5150's are a nice setup but lack valving options $65-$125, the 7100's are awesome and have lots o options but are kinda pricey..$188
im likeing the BBCS shocks very nice setup and have an integrated bumpstop and are specifically valved for rock climbing $110
im kinda leaning towards a cheaper but ok option lol doetsch tech 8000 pre-runners...their $40 ish, have good reviews and also have an integrated bump stop...sweeeet
all prices are Each and from poly performance...except the doetsch tech's hafta buy those direct or from somewhere els..
and friggin kudos on the motor dude AWESOME wish i had the dough to do that!
