Toyota factory e-locker 2001
Before you all jump on me for the "search" button..I used it and I found nothing for me.
I want to know...with a 2001 4runner SR5 ..can I put on a factory toyota e-locker on, or does the wiring for the darn center diff lock get in the way?
or would you all suggest another locker? ARB? Detroit?
can you pot the toyot Elocker on the front like you can the ARB?
sorry..I'm still a new guy
Re: Toyota factory e-locker 2001
Re: Re: Toyota factory e-locker 2001
Originally posted by transalper
If you have the cash and use your rig as a daily driver, go for the e-locker or ARB. Both are great units.
Nope. Go ARB!
Nope. Go ARB!
would you mix n match factory e on the back and ARB in the front...or would you go all ARB front and back?
Re: Re: Re: Toyota factory e-locker 2001
How do you like the Viair 450 Compressor..and why did you not get the arb compressor?
I like it. The ARB compressor is fine for lockers but is kinda weak for airing up tires. The Viar 450 is 100% duty cycle and puts out almost twice as much air as the ARB.
Thank you..
Thank you..
there is no way to put on a factory 4runner e-locker on the front??
if not I think I will go ARB locker on both the front and back..but I would rather have an E-locker then an air locker
has used an Aussie locker? I ahve seen the ad and read the thing on here..but I want to know how well it works..
p.s. bump
p.s. bump
p.s. bump
You are kinda comparing apples and oranges with the ARB and the Aussie. I am choosing to go with the Aussie because it is relatively easy to install compared the ARB and the E-locker retrofit, and it is way cheaper. $200 is my kinda range. Keep in mind the AL is a full-time locker that disengages when turning (its supposed to anyway). If you can handle some clicking and two wheels putting power to the ground in almost every situation, than the Aussie is for you. If you want full control over your locker, then ARB or the E-locker your ticket.
so the aussie is like a spool or auto locker or limited slip? and the other two are selectable.
my rig is a daily driver..
a click or two around croners is ok..but I would rather it be totally open until I need it locked..
I do not know what the heck I want :cry:
oh well, such is life
From: Home: Aurora, CO; Work: The People's Republic of Denver
The only drawback I can think of for the e-locker retrofit on the 2001 is that the wiring & ECU for the Multi-Mode system is completely different and the wiring for the e-locker is nonexistant. You'll have to wire in a complete e-locker system including the ECU and interface it with the Multi-Mode system for it to work "stock". AS for the ARB's, I'm leaning toward them with the Vlair compressor when I have the money due to the relative cost & ease of installation.
Are you looking for a price breakdown? Jay (transalper) linked his costs above for the front, which would be pretty close. Mike recently quoted me $630 for the locker (recent price increase), $210 for the compressor, then Jay added ~$100 for misc. parts, if I read that correctly. You might be able to lower those prices only by a little by shopping around. I seem to recall a previous link in the past to a place where the compressor was a bit less, but I think all you would need to do is to make a local call to Mike and be done with it.
Originally posted by rwmorrisonjr
The only drawback I can think of for the e-locker retrofit on the 2001 is that the wiring & ECU for the Multi-Mode system is completely different and the wiring for the e-locker is nonexistant. You'll have to wire in a complete e-locker system including the ECU and interface it with the Multi-Mode system for it to work "stock". As for the ARB's, I'm leaning toward them with the Vlair compressor when I have the money due to the relative cost & ease of installation.
I'm not trying to sway anybody one way or the other. I've only had the e-locker for a short while, but had a rear ARB in my last rig. Both did what they were designed to do, which is get me burried even deeper.
I guess I am looking more to the ARB. does most of the people who have the ARB lockers also use the ARB compressor..or do you use a bigger more powerful one?
That is what I was asking...if there was going to be any problem for people who do not have the partial wiring of the system.
Most use the ARB compressor because it is the ARB compressor. Plus it comes with all the wiring, pressure switch, dash switch, and has a small integrated air tank. It makes the install very easy. The locker switch, solenoid, and air lines come with the locker.
Theres some great information being posted here. Another thing I'd add is that there's something to be said for having the same technology front and back. For myself, who already had the elocker in back, I'd just go ARB up front and be done. But if I didn't have either, I'd probably do front and back arbs. Someone correct me if I'm wrong, but with the ARBS, if the compressor craps out, the diffs will unlock since they need the positive pressure of the compressor to stay locked. The elocker (I think) will remain locked if you run into problems with the switch, wiring, etc. This could be a problem once you hit pavement again and couldn't unlock your diffs. The odds of this happening are pretty low, but just one more thing to think about. The front diff is too small to house the elocker, so it just isn't possible. The advantage of getting the ARBS is that you're set up with onboard air for airing up tires now.
I think most people would agree that the biggest gains will be seen with the first locker in the rear, and more "marginal" gains locking the front. If it were me, I'd just get the rear ARB installed, wheel a little while, see how you like it, see if you're getting stuck. You might find out that the rear is all you need for the wheeling that you do, and save some money in the process. On the other hand, if 4 months down the road, you decide to lock the front, you're already setup with with the air compressor.
One more thing, then I'll shutup. If you plan on running bigger tires at some point, it might not be a bad time to regear at the same time as well. You could get two replacement diffs set up with new gears/arb lockers, and be done.
Originally posted by Mad Chemist
the elocker (I think) will remain locked if you run into problems with the switch, wiring, etc. This could be a problem once you hit pavement again and couldn't unlock your diffs.
