3500 rpm idle. need help
Old Aug 30, 2011 | 12:10 PM
Ned's Avatar
Ned
Question 3500 rpm idle. need help
Ok. A little history first. I did the mod where you remove the boxes attached to the intake tube and replace them with PVC pipe caps.
A week ago I went to Silver Lake Dunes and played. While I was driving home on the expressway, I accelerated to pass a slow car and as soon as I put the petal to the metal, my truck sputtered and died. I pulled over and found my intake had sucked one of the PVC caps in. I fixed it and continued home. But when I got off the highway and slowed for the traffic light I found my truck was idling at 3500 RPM. So that's where I'm at. My 96 4Runner idles at 3500 RPM no matter what. I took it apart today and cleaned everything. MAF, TB etc... I was thinking maybe when my throttle was wide open and it sucked in the PVC plug at warp speed it bent my butterfly valve in the TB. I looked at it and this is what I found. It looks like my butterfly has shifted in/ down. There is a gap in the top and it looks like you can see where it has shifted on the shaft. Is this possible? What is the fix if so? New TB?
Old Aug 31, 2011 | 10:34 AM
Ned's Avatar
Ned
Anyone know if this gap should be there or not?
Old Aug 31, 2011 | 03:34 PM
Ned's Avatar
Ned
No one has any thoughts?
Old Aug 31, 2011 | 09:18 PM
J2F42C's Avatar
As long as you can manually rotate the butterfly on the TB without it scraping the chamber, you should be OK.
Take a look for any vacuum hoses you may have missed starting with all of them that come off the upper manifold.
Old Aug 31, 2011 | 09:32 PM
stockwell45's Avatar
Check all cables, have someone push the pedal with the 4runner off and see if it opens the butterfly valve correctly. There could be something sticking at the pedal area, but everything looking fine at the TB
Old Sep 4, 2011 | 02:09 PM
Ned's Avatar
Ned
hmmmm... I'm at a loss...
Old Sep 5, 2011 | 01:14 PM
Ned's Avatar
Ned
well I was right. The valve in the TB had shifted. I got a used TB off Ebay and it fixed the 3500 RPM issue. But it has created another issue. Please see THIS post.
Longbed 90
Oct 19, 2015 11:05 AM
Sam hain
19
Sep 30, 2015 08:25 AM
voiddweller
Sep 28, 2015 11:21 PM
accuracy
Sep 20, 2015 07:44 PM
Mrfobbyaccent
Sep 10, 2015 12:13 PM
