89 4Runner 3.0 5spd sr5 to 97 3.4 and sas build-up
Old Aug 22, 2011 | 05:59 PM
MK3Supra's Avatar
I picked this 89 4runner up one weekend in may for $1000 in Deland, FL about an 8hr drive there for me after months of looking around southern AL. for one and looking at over priced ones with lots of issues. Then 2 weeks later picked up a 97 4runner 3.4 4x4 limited with a E-locker 3" body and 2" susp lift 33" tires for a STEAL $400it had a crack in the radiator and no title. I'll be updating as i get further in to the sas and 3.4 build. currently it has a 4" susp and 3" body lift on 35" BFG KO it had a blown front diff when i picked it up. Here ar some pics this is my first time posting hopefully i added the the pics the right way.
89 4runner
Doner 97 4runner
Old Aug 22, 2011 | 06:21 PM
YOTAZOMBIE's Avatar
NICE!!!! So are you going 2 install the 97s rear end in the first gen or just the E locker?
Old Aug 22, 2011 | 06:24 PM
MK3Supra's Avatar
Just the E-locker and i picked up one for the front at barry's u-pull it down here for $50 last week
Old Aug 22, 2011 | 06:37 PM
YOTAZOMBIE's Avatar
Wow congrats on the purchases man. I need some of your luck for when i go junkin man
Old Aug 22, 2011 | 07:01 PM
turbotoyz's Avatar
Subscribed! You forgot to say there are 3 4runners on that property haha!
Old Aug 22, 2011 | 07:07 PM
MK3Supra's Avatar
Originally Posted by turbotoyz
Subscribed! You forgot to say there are 4 4runners on that property haha!
only 3 and a half with parts cuz
Old Aug 22, 2011 | 07:23 PM
MK3Supra's Avatar
Here are some pics of the wiring, engine.
My finshed 89 man to 97 auto harness
turbotoyz 00 3.4 on the left and my 97 on the right.
Old Aug 22, 2011 | 07:34 PM
McTibbs's Avatar
Subscribed!
Old Aug 30, 2011 | 05:54 PM
MK3Supra's Avatar
My diff armor, front truss, solid pinion spacers, e-locker harness and studs came today so i started welding them on. tomorrow i should be getting the R&P install kits so i can work on setting up the e-lockers.
Cutting the diff housing to fit the e-locker
Setting up the truss to weld
starting to paint the calipers and knuckles
Old Sep 21, 2011 | 06:13 PM
MK3Supra's Avatar
OK i started my sas last week after realizing that T.G. shipped me 1 hd spring and 1 none hd so i had to wait a week for them to ship me another hd spring i did all the prep work, setup the e-lockers with 5.29 gears, ifs hubs with tacoma rotors and here are some pics.
Now i just need to buy a long spline front shaft. So i can flex it completely without the driveshaft going into 2 pieces. Using front driveshaft from a 97 4runner.
Need to do relocate steering box forward, hydro assist, lift rear and bumpers.
Old Nov 9, 2011 | 08:35 PM
MK3Supra's Avatar
So i finally swapped in the 3.4 the other weekend since the waterpump, valve covers and rear main seal started leaking on the 3.0. I'll post some pics this weekend when i get a chance.
Old May 5, 2012 | 03:34 PM
MK3Supra's Avatar
So i bought a R151 w/t-case for dirt cheap and found a extra t-case on car-part.com for $150 to make my dual case setup. Triple stick setup thanks to RADesigns products.
Old May 5, 2012 | 08:23 PM
rustED's Avatar
Man you come across some sweet deals! Your Runner is coming along really good, that thing is going to be bad@$$ when you get done! Keep up the good work!
Old May 5, 2012 | 08:33 PM
89yoters's Avatar
nice work! and thanks for the post very helpful. i am planing on doing the same thing on my 89 pickup. just need to find and 84, 85 axle and a welder.
Old May 5, 2012 | 09:12 PM
RMP8080's Avatar
Great job on the SAS, your runner is coming along....thanks for the pixs....Bill
Old May 6, 2012 | 07:50 PM
runs-on-4's Avatar
looks sick!
Old May 6, 2012 | 09:12 PM
RMP8080's Avatar
Hey mk3, like the Jetta TDI......
Old May 7, 2012 | 07:21 AM
Zelephant's Avatar
That body lift needs to go away. Like right now.
Aside from that, looks good!
Old May 7, 2012 | 02:49 PM
MK3Supra's Avatar
Thanks But its not mine its Turbotoyz.
LOL I removed the 3" body lift and replaced it with a 2" after swapped motors.
Old May 7, 2012 | 03:22 PM
MK3Supra's Avatar
I'm starting to fix the bad bondo job since its cracking and opening up my rear wheel wells.
From the rocker panels to about a foot up was filled with Great Stuff foam.
