Pre 84 Trucks 1st gen pickups
Anyone know what was cut off my axle?
Old Jul 14, 2011 | 05:58 PM
Crimson Yota's Avatar
Does anyone know what was cut off my front axle? It's an '82 pickup and based off the writing on the axle, it isn't original.
Looks to me like something was cut off the driver's side, its got weird melted metal on it that looks like it was cut off with something, here's some pics (lots of fuzzy seeds)
Anyone know what was there, if anything?
Old Jul 14, 2011 | 06:08 PM
toyota4x4907's Avatar
Torque rod.
Old Jul 14, 2011 | 06:10 PM
Originally Posted by toyota4x4907
Torque rod.
Thanks, know why?
Old Jul 14, 2011 | 06:14 PM
Why it was on there? To reduce/elimiate axle wrap and keep the axle aligned.
Why it was cut off? Probably due to lift.
Old Jul 14, 2011 | 06:18 PM
Something I should worry about not having?
Old Jul 14, 2011 | 07:03 PM
87hillbillyoter's Avatar
looks like what i cut off mine. im putting a truss on thats why i cut it. i have no idea what it is. apparently a torque rod
Old Jul 14, 2011 | 08:00 PM
Never seen an SAS with a torque rod, but yours is factory, correct? being a pre-'86. I think you'll be fine...
Old Jul 14, 2011 | 09:05 PM
twistedyota's Avatar
its a torque rod.
i believe most people cut them off. for as few reasons.
1. on a SAS you dont have a place for it to mount.
2.you cant lift your trucks without having to remove it or modify it
3. (not fully sur here) i think people also remove them because when changing the front springs to something not stock it is no longer needed.
Old Jul 14, 2011 | 09:36 PM
dropzone's Avatar
Fossilized
cut mine off because it would get in the way of my high steer.
Running 35's my truck seems to handle fine with out it.
you might check out 4Crawler's site. I think he has something there about the pro & cons...
Old Jul 18, 2011 | 09:45 AM
peow130's Avatar
I think someone mentioned in another thread, that with stock steering, under hard braking it has a tendency to pull hard to the right. That is, without a torque rod of course.
The only other reason i can see it, is to prevent axle wrap in 4wd.
Old Jul 18, 2011 | 07:30 PM
4x4YOTA's Avatar
I dont run mine and truck still drives great...
with out it you will have wondering during hard braking situations but still controlable Ive been with out mine fore years and never had a problem and never felt unsafe
88sasturbotoy
Jan 30, 2026 01:57 PM
polo451
13
Nov 20, 2016 07:49 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Cbr954ryder
Jul 25, 2015 06:32 PM
crashburnoveride
Jul 10, 2015 06:39 AM
