200,000 cooling system replacement items
So I'm going through the truck replacing parts that could affect my lifespan and while underneath I noticed the rear heater coolant lines were almost rusted away.... not to the point where coolant is dripping out but close. So I am going to replace the radiator/cap, upper and lower hoses, thermostat, fan clutch, rear heater sub assembly lines, add external trans cooler. Other than the trans cooler I gotta search online for OEM... since the originals lasted 200k. Is there anything else I'm missing when ??
FYI, I recently bought an Aisin water pump for my 3.4 on ebay for 65 bucks, shipping included. Until recently I didnt realize I could get good OEM parts on ebay. Shop there too, if you dont already.
Marley,
I am in Elizabeth City, NC and work in Portsmouth VA. I guess I can claim that I am in the OBX only in name, even though I did live in Wanchese, right behind Roanoke Sound for a year.
I had a friend from the University of Richmond who worked at the Canon Ridge Golf Club outside of Fredericksburg on the river during summers. Nice course to play.
Like others have said, a T-belt and H20 pump change if it has not been done lately.
If the radiator is original, and you have an automatic, consider bypassing it or replace it with a Koyo 1998A
I replaced the timing belt and water pump etc at 100k and was planning on including these as well. I am attaching some pics that started this thread after discovering the rust on these lines. There is corrosion and what looks like rust on a coolant line T connector of some sort in the first picture and then rust on the lines in the other pictures. Thats when I was trying to price that rear sub assembly and replace that with radiator etc etc. I have no experience whatsoever with anything coolant related so I'm hoping to just gather my parts and figure out who to install. I'm afraid these rusty lines are going to break if I delay.
OK here is the list as it stands now and I'll have to update with the factory part numbers when I locate the rest.
Timing belt (dealer)
water pump (dealer)
idler pulleys (dealer)
cam crank seals (dealer)
thermostat (dealer)
fan clutch (dealer)
radiator (KOYO 1998A go-part.com)
upper/lower hoses (dealer)
rear heater line (dealer 87248-35061)
trans cooler (B&M 70264 http://www.summitracing.com/parts/BMM-70264/)
OEM or Zerex coolanthttp
water pump (dealer)
thermostat (dealer)
fan clutch (dealer)
So is a fan clutch a fan clutch? I know the bennies of sticking with Toyota parts but working on picking up replacement items and the fan clutch through the dealer was about $170 but I found a beck/arnley, four season, and hayden on RockAuto for $85, $70, and $65 respectively. Just trying to figure if the dealer clutch is worth more than double.
In the Land Cruiser world, we just change the oil in the fan clutch and call it good. It's actually a serviceable item. I assume the 3.4 fan clutches are the same - of course I could be wrong. I was planning on changing the oil in mine as part of my timing belt replacement but that project got a little off track.
I believe the stock oil is 3000cst. I put 8000cst in my Land Cruiser fan clutch and a lot of guys in hotter climates run 15000cst. The oil is the same stuff that's used in differentials for RC cars, available anywhere you can get those parts - Like Hobby Town.
If you head over to IH8MUD and check out the 80's section, you'll find a ton of info. I could dig up some links if you want.
thanks for the partsgeek info... looking at it now. I didnt even know that it would even be a serviceable item? I looked in the FSM last night and didnt see that listed but just figured if it were going to go it would make noise or overheating would occur while stopped. I havent been overheating but was stuck in 100+ degree traffic jam this past weekend and the temp gauge starting rising even after the ac was cut off. I just wanted to include a replacement clutch with the coolant flush and the water pump/thermostat change etc.
I think the oil is changeable, and there was even a thread on here a couple of years back concerning this, but when I asked a couple of mechanics before replacing my clutch, they looked at me with utter puzzlement. Good to know now, but I just put a new Aisin one on not 5,000 miles ago.
water pump (dealer)
thermostat (dealer)
fan clutch (dealer)
water pump (dealer)
thermostat (dealer)
fan clutch (dealer)
free shipping
go-parts.com shows my radiator for 140 plus shipping
radiatorbarn shows it for 122.79 delivered
https://www.radiatorbarn.com/search....oduct=radiator
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
