Pre 84 Trucks 1st gen pickups
Sputtering under load
Old Jun 29, 2011 | 09:29 PM
the big d's Avatar
Well the yota was running fine until today with sputtering under load above 40mph, it wouldn't take any gas. I pulled one of the plugs and it is dark so I know they need to be replaced. But since the truck sat for over 2 years would the carb likely need cleaning if it ran fine for 300 miles this week? I'm used to the fuel injected world.
Old Jul 4, 2011 | 01:38 PM
the_supernerd's Avatar
Sputtering under load could be caused by bad plugs and wires. I would give it a full tune up before anything else, especially if the plugs are old.
It could be something in the carb, but I would start with the basic tune-up. Properly gapped plugs, wires, cap, and rotor. New fuel and air filters, a valve adjustment and ignition timing check would also be a good idea. It would not hurt to clean out the throat of the carb with some carb cleaner at the same time, but I would wait to rebuild it.
Old Jul 5, 2011 | 07:49 PM
the big d's Avatar
Plugs and a shot of carb cleaner did the trick, still need to do the rest of the tuneup but it is now at least driveable and its smooth and enough power. I keep thinking that plugs last 100k on the thing instead of 20k.
Firefightersink15
Nov 23, 2015 10:32 PM
smilen724
13
Nov 8, 2015 04:11 PM
MichaelKLerner
Oct 27, 2015 07:18 PM
93RedKrawler
Sep 25, 2015 04:03 AM
Gutted91
Sep 17, 2015 05:44 PM
