easiest and cheapest 2in lift?
Hey!
What kinda truck do you have? That would probably make a big difference on prices.
Somebody correct me if I'm wrong, but the cheapest way to do a small lift on a 2nd gen would be just to through some coils in the rear and crank the torsion bars, right? Probably around $200. Not sure if you could get 2 inches on the front from cranking the torsion bars though, especially if your truck is 4x4.
There are people here that know much more about lifts than I do, but just thought I'd through in what I have gathered.
Have fun.
DH6twinotter
Have fun.
DH6twinotter
Re: 97 4runner, sr5
Originally posted by dirk diggler
97 4runner, sr5
sorry to leave out that crucial piece! thanks, dd
97 4runner, sr5
Have fun.
DH6twinotter
2 inch Roger Brown body lift
another option...
Front for now rears should be available within a week or two.
"Almost Free" as they say in Baja! LOL!
http://www.protechezlift.com/
i like it!
protech is a great solution for me! how easy are spacers to install? i am, unfortunately of limited tech skill. also, aluminum seems a little sketchy considering the fatigue life regarding cracking and the inability to weld. why aren't spacers made out of steel? thanks, dd
I haven't done any calculations, but I wouldn't think there would be very much stress on the spacer since it's so big. Plus, it's constantly under compression and I wouldn't think the cyclic load would vary enough to matter.
Why would you want to weld on a spacer?
Aluminum is much easier to machine than steel.
thanks for the info
yeh, aluminum is easier to machine, but alway worried about fatigue, micro-cracks etc, especially on such a load bearing part. welding is in case of cracking, a steel spacer could be fixed. anyway, are these things easy to install or should i let the pros do it? thanks, dd
Well, Al spacers for these coils have been around for a while and I've never heard of one failing.
Installation is cake if you can turn a wrench. Check out the tech articles for more info. https://www.yotatech.com/~corey/tech/techpage.htm
Re: no love
on the tech page for spacer installation, i'll do a search. thanks, dd
Basically, you unbolt the shock assembly and remove it from the truck (4 bolts). Use a spring compressor to compress the spring and then take apart the assembly (1 nut). Throw in the spacer and bolt everything back up. See, only takes 3 sentences, much like it only takes a couple paragraphs in the chiltons to discribe how to take apart a CV axle.
Plays with toys, spacers only work for coils. Besides, cranking the Tbars does exactly the same thing, but for free. (read my suspension page)
