Leak in bell-housing
Old Jun 12, 2011 | 09:31 AM
xylicon's Avatar
I'm in the process of swapping the motor in my truck. After it was removed I noticed some fresh oil in the bell-housing, any idea as to where it could be coming from? Easy fix?
Thanks (:
Old Jun 12, 2011 | 09:57 AM
scuba's Avatar
Rear main engine seal or trans input shaft seal.
Old Jun 12, 2011 | 10:16 AM
DeathCougar's Avatar
This.
These are the only two seals that would allow oil to flow directly in to the bellhousing.
Since you have the engine out, yes its an easy fix. Replace both seals. The input seal will require you to remove the input shaft collar.
he's gone
7
Dec 3, 2019 07:08 AM
4runnerjunk
Aug 22, 2015 09:06 AM
accuracy
Aug 4, 2015 08:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
